Moving Tank birthday cake by dave spencer
Contest WinnerFeatured
Super great timing on this cake contest! It's my sons birthday again. Obviously his cake had to be something out of the ordinary. See past cakes -
volcano
helicopter
we were just on vacation at Disney so I didn't want to get too elaborate due to time constraints. My son asked for a tank cake. I'm sure he would have been happy with a cake with a picture of a tank on it or a model tank. But I would not have been happy. First I decided that the turret would rotate. That is pretty easy. I toyed with the idea of having it shoot something (what says happy birthday more than getting shot in the face with whipped cream) That idea got shelved as soon as I imagined the look on my wifes face. To up the difficulty level I decided to make the gun go up and down as the turret rotated.
-Imagine wife smiling-
It is a little difficult to see the gun raising and lowering due to a bad camera angle. Look at the camo icing and the gun shield and you can see what is happening.
Please check out my other instructables and I also have a diy podcast called mechanicalmashup.tv
Step 1: The mechanism
I started with some scrap parts I had laying around, mostly stainless steel. The stainless sheet metal was the same piece of scrap I used for the volcano cake last year. Since it was not going to shoot anything, I started with a solid stainless barrel, welded a bracket and a pivot onto it, and fixed it to the turret pan.
By the way, nothing puts a smile on my face more than describing how I make cakes with a welder:)
To make the gun travel up and down, I decided to make a rod and cam type system. I welded a guide tube to the turret pan and made a "cam" of sorts out of a metal disk that I heated with a torch and bent randomly. I then fixed this to a tube that would act as a bushing for the turret pan rotation.
I had a slow turning motor sitting around the house and mounted it to a piece of wood as a base. I welded legs to the cam and drilled them into the wooden base. I set it all on a bit of an angle so the tank would be tilted slightly when done. You can see that the turret pan warped a bit during welding but I was not too concerned and I did not bother to correct it. The push rod was installed to slide along the cam and raise the barrel.
The last thing I did was put on the barrel guard. I used perforated steel for two reasons, one was it would be really easy to bend a slight curve into it and two was so the icing would have something to adhere to.
Step 2: The cake
The turret pan was hot glued to another piece of wood that was to act as the base. Anything that was to touch cake that was not stainless was covered with tin foil.
I made 4 cakes for this. One cake was baked in a pot the same diameter as the turret pan. A little bit of carving and I had my turret shape and clearance for the barrel and mechanism.
The other cakes were baked in a 9 x 11 inch pan. Once cooled the rounded tops were sliced off. These tops were used for the ground. The main parts of the cake were carved to fit around the mechanism and stacked to create the rough tank shape. All pieces were "glued" together with icing.
A bit of carving with a sharp knife and it was starting to look like a tank.
Step 3: The icing
I planned to use fondant icing right from the start. This was my second attempt at using the stuff. I wish I could take a course on the application of fondant because it really can't be as hard to work with as I find. What a pain in the butt this icing is!
To get the fondant to stick to the cake, you need to ice it with regular icing. It is way easier to ice if you freeze the cake first.
It is way easier to freeze the cake if you check the dimensions of your freezer prior to building the base!
I had to shuffle a lot of food around but I eventually got it to fit. Oh well, this was a seat of the pants project to begin with.
I mixed colours into the icing as I just bought one big white tub of fondant. The fondant needs to be rolled onto wax paper because it is quite sticky. It even sticks pretty well to the wax paper. I found this to be to my advantage in some cases as I rolled out the tracks. After I used a piece of wood to put the tread in, I stuck a piece of wax paper on top, flipped the whole thing over, peeled off the new top side of the wax paper and used the othe strip of wax paper still stuck to it to move it to the cake, placed it on the cake and then peeled the wax paper away.
One bit of foresight I had was to make the turret easily removable. This helped in decorating more than I can express. I perched the turret on a pitcher so it would not tip over on the push rod or the axle and decorated it there. The stainless barrel was wrapped with fondant and a little bit of detail was put on like a hatch with periscope.
Wheels were added on the side, these were just icing rolled flat and cut out with various sized cups and caps. The camouflage was added by smooshing random shapes. all detail is stuck in place by simply wetting the area you want to fix it too.
The last step was to crumble up some cookies to make the dirt the tank was driving on.
That's all folks! hope you enjoyed this and see you again next year for Brody's 7th birthday.
I'll post a vid of him blowing out the candles in a few days.
Step 4: Blowing out the candles
Note the screen on the laptop.
Brody the birthday boy had seen the cake several times prior to this, so that is why he is not too surprised.
Thanks to all the people who have come out to vote for us :)
jasonmusic1 says: Mar 13, 2010. 9:16 AM
i think you are the coolest dad on earth! i strive to be this creative for my girls. unfortunately they are not into tanks. maybe i could make a spinning barbie!
Duct Tape Dude says: Jan 2, 2010. 2:48 PM
Im gonna (try to) mod it to be the Scorp off Halo!
ampRiser says: Sep 9, 2009. 8:23 PM
This is Great, Very cool Idea!
uberlush says: Aug 7, 2009. 8:40 AM
i wish my dad made me cakes as good at that. unfortunately he cant cook, let alone handle the mechanics :L
codongolev says: Jun 9, 2009. 9:40 AM
if you wanted to make it shoot stuff, you could fill some sort of squeeze pump (balloon possibly) with whipped cream, then run a tube up through the gun down under the table, then squeeze it at just the right time.
Sunny124613 says: Sep 1, 2008. 4:53 PM
very very nice I have never seen someone use fondant this well EXCEPT DUFF GOLDMAN!!!!
supersith22 says: Jul 8, 2008. 6:25 PM
Wow. If I were you I'd be expecting a call from Duff Goldman sometime soon! very nice.
jimofoz says: May 5, 2008. 10:40 AM
Why do so many people gripe about stuff like this. It looks cool and that's what counts. Good job.
ahcmachinist says: May 4, 2008. 10:57 AM
There's no mention of the motor, could you give us some info?
dave spencer (author) says: May 4, 2008. 5:57 PM
it was a 6v 3rpm motor and gearbox I bought from allelectronics.com a while back. It was the second of a pair I bought. The first one was used for the pneumatic firing system on my volcano cake last year.
Zetheros says: May 3, 2008. 9:18 AM
You have such a lucky kid ;)
yoshmar2 says: May 2, 2008. 4:10 AM
really cool id love to have a cake like that i think you have to have a great mind to come up with something like that your kool
Pocket Universe says: May 2, 2008. 1:01 AM
And here I thought that cakes you could buy in a shop were posh... Really great work, your son must have been thrilled.
razany says: May 1, 2008. 4:58 PM
I'd feel bad eating this, its looks so awesome!
I saw your other cakes, and they're just amazing! Great job! =D
uberdeity says: May 1, 2008. 3:59 PM
That. Is. AWESOME! Beat's my articulated cake out of the water (it used hard moulded icing to create a just-about-working ball bearing so the top could rotate). Thank you, sir- you may have just let me top that! Again, let me say that this is an awesome cake and your kid is lucky to have you!
MakerBreaker says: Apr 30, 2008. 12:45 PM
....half the thing aint even edible
MakerBreaker says: Apr 30, 2008. 4:08 PM
but i dont think it would be easy to cut and eat it because its hard not to make a cut into the cake about 1 inch without hitting metal
dave spencer (author) says: Apr 30, 2008. 4:48 PM
I told my wife to cut it because I didn't want to be the one to wreck it. She had no problems and she did not even see it prior to the cake being placed on it. We ate the entire top at the party less one small piece. The next day my wife took it to her work and everyone was cutting their own pieces. No one complained about hitting metal. every last bite was gone, top and bottom.
MakerBreaker says: May 1, 2008. 12:10 PM
but ill stick with the triditional cake....this one looks cool but looks complicated
dave spencer (author) says: May 1, 2008. 1:24 PM
You go ahead and stick with uncomplicated stuff. Just know that you may be in the wrong place right now. BTW it took longer to ice the cake with fondant than to design and build the mechanism. If thats what you want to call complicated, you go ahead.
dave spencer (author) says: Apr 30, 2008. 1:57 PM
sorry you are mistaken. Have a look at the pictures attached. That is all the steel in the cake. everything else is cake. Thats got to be 90% cake.
fred531 says: Apr 30, 2008. 8:24 PM
+1. Great idea. Kid looked really happy in the end =)
hernanai says: Apr 30, 2008. 6:35 PM
Favorited... My girlfriend is going to make me one like this... minus the moving parts... (I want to keep it 100% edible...)I give you Two Thumbs Up...
=SMART= says: Apr 28, 2008. 2:33 PM
Wow you got an article about your cake on Gizmodo!
http://gizmodo.com/384801/loving-dad-bakes-son-a-motorized-tank-cake
Congratulations!!
gimmelotsarobots says: Apr 30, 2008. 11:39 AM
Makezine too!
=SMART= says: Apr 30, 2008. 12:43 PM
cool!
samando says: Apr 26, 2008. 3:13 PM
just a question, with all the metal in it, is the actual cake still edible? and if it is, good on ya!
dave spencer (author) says: Apr 26, 2008. 3:46 PM
Yeah dude, when you look at the cake, there are two levels of pan, one for the turret and one for the base. The only thing you could not bite in the picture is the barrel. It's all stainless steel or tinfoil so its all food-safe. By the way, the cake was delicious!
samando says: Apr 27, 2008. 4:28 PM
Genius!
canida says: Apr 27, 2008. 11:00 AM
Wow! I think you win the "coolest dad ever" award.
=SMART= says: Apr 27, 2008. 8:19 AM
i want this
+1 rating and +1 vote
thebboy says: Apr 26, 2008. 8:37 PM
SWEET +1 and vote
Spint says: Apr 26, 2008. 3:33 PM
Awesome you got my vote.
mitchell931993 says: Apr 25, 2008. 11:59 PM
that grilling stuff might be a bit dangerous to the little ones might wanna file it down a bit-and mention it in the instuctables so people don't sue you cause there favorite rug got wrecked buy a toddlers blood.
dave spencer (author) says: Apr 26, 2008. 7:16 AM
everything I cut had sharp edges that had to be deburred. you could grab any part of it now and not get hurt.
cowscankill says: Apr 26, 2008. 6:37 AM
Snap! +1
LinuxH4x0r says: Apr 25, 2008. 10:08 PM
Cool! Another great cake from you. keep up the good work!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
