Step 1The mechanism
By the way, nothing puts a smile on my face more than describing how I make cakes with a welder:)
To make the gun travel up and down, I decided to make a rod and cam type system. I welded a guide tube to the turret pan and made a "cam" of sorts out of a metal disk that I heated with a torch and bent randomly. I then fixed this to a tube that would act as a bushing for the turret pan rotation.
I had a slow turning motor sitting around the house and mounted it to a piece of wood as a base. I welded legs to the cam and drilled them into the wooden base. I set it all on a bit of an angle so the tank would be tilted slightly when done. You can see that the turret pan warped a bit during welding but I was not too concerned and I did not bother to correct it. The push rod was installed to slide along the cam and raise the barrel.
The last thing I did was put on the barrel guard. I used perforated steel for two reasons, one was it would be really easy to bend a slight curve into it and two was so the icing would have something to adhere to.
Add Comment
