Tanto Knife
Introduction: Tanto Knife
It's my third attempt to make knifes. I use Uddeholm Arne tool steel, 6mm thick.
Step 1: Grinding
I used Uddeholm Arne tool steel, 6mm thick. But the knife should be about 4.4 mm thick, so it should be ground.
Step 2: Shape of the Knife
Cut the blade with an angle grinder
Step 3: Finishing the Blade
Finish the final shape of the blade with a twin grinder
Step 4: Hardening and Tempering the Steel
Heat the metal to a medium-high orange heat, until the steel becomes non-magnetic. Just tap it against the magnet while it's glowing, and if it doesn't stick, it's ready. Then plunge it into the oil bath. After that, choose the tempering temperature according to the hardness required by reference to the tempering graph. Temper twice with intermediate cooling to room temperature. Lowest tempering temperature 180°C (360°F). Holding time at temperature minimum 2 hours. (PB_Uddeholm_arne_english.pdf)
Step 5: Final Shape
The final shape of the knife
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    It' s very sharp!!! I cannot estimate precisely the time, because the process wasn' t continuous, but it' s about 10-12 hours
    Awesome! These look great! How sharp are they and how long does it take to make one? You should try to make a micarta handle.
