3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tapping a Square Hole (Square to your material that is!)
I have always been vexed by having to tap threads in a hole so that the threads are square to the top of the material I was tapping. I found a nice solution using a block with a groove in the side.
Step 1Insert tap into hole
Start by putting the tap in the hole. Notice the tap I am using has a somewhat flat profile on its side.
15 comments
Jan 17, 2010. 1:47 AMsharlston says:
add some tapping lubricant like break free they go a long way
Dec 30, 2009. 7:38 PMDavad says:
If you can get your work under a small drill press, then why not put the bit in the chuck, removed the drill press belt and turn the chuck manually?
Would it be possible to use a same size die to guide the tap bit into the hole?
Dec 30, 2009. 7:39 PMDavad says:
Great idea.
Dec 16, 2008. 7:50 AMcamperken says:
What y'all need is a tapping block. Mine is about 1 1/4 tall and 3 x 3in on a side ot of steel . I've drilled in a drill press holes for every size tap from #6 - 1/2 in. This starts every tap in straight. You could make it out of plastic, al., wood. anything that is flat. For getting holes in straight by hand. I first pilot drill with a small bit. Small like 1/8 or 3/16 . Then I used a bigger dril and since The force to start drilling is so small I can concentrate on watching and making sure its square. I'm talking about drill in something relatively hard here like steel, al. ect.
Oct 6, 2008. 12:27 PMMisterSlippy says:
Cool instructable. I never seem to have a problem finding the vertical with drills and taps unless I'm working at an awkward angle. Something like this would be perfect for those situations.
Oct 6, 2008. 12:29 PMMisterSlippy says:
Also, you only need one or two such tools. As long as the hole is large enough to take the largest of your taps, you can pack out a selection of smaller taps with rubber sleeves or heat shrink over the shaft. Presto hey, one size fits many.
Oct 3, 2008. 5:02 PMkillerjackalope says:
Handy little tip, one other thing I can think of is to take a tapping tool and modify it in to a little jig frame to make it specifically for making nice square threads. By the way delete step four, it's empty. I added a few keywords to your 'ible to help with searches as well.
Oct 3, 2008. 5:12 PMkillerjackalope says:
Ah maybe one to put on hold until you're free of time or embarking on something that would really be helped by such a tool... So we're likely to see some more projects soon then?
Oct 4, 2008. 10:11 AMkillerjackalope says:
Impressive, I may have to have a look at that gantry system, it supports you pretty well and I have a little project I'm planning that could benefit from such a thing...
Oct 4, 2008. 8:29 AMdoommeister says:
DoomMeister hate's tapping holes too.
This looks like a solution, however you would need one for each size of f tap you use. So perhaps it would be worth making the spring loaded tube or even investing in something like this.
One tip I can offer is that if you use a drill press or miller to drip a hole that needs to be tapped then before you move the workpiece is place the tap in the drill chuck and start the tap by hand using the column to keep the tap square, this also works on lathes. Just be sure to knock the power off first (at the safety cut out preferably).
Oct 4, 2008. 9:09 AMrimar2000 says:
Good idea. For me, always this has been a problem.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ruzter
