Introduction: Taser Glove :D
Picture of Taser Glove :D
WARNING: THIS IS DANGEROUS VOLTAGE, DO NOT USE BATTERIES THAT ARE FULLY CHARGED,
DO NOT USE THIS ON YOUR PARENTS, TEACHER OR PEOPLES WITH HEART CONDITION.
ALWAYS USE THIS FOR SELF-DEFENCE PURPOSE ONLY, DO NOT USE/TAKE THE TASER-GLOVE WITH
YOU AT SCHOOL.
CHECK YOUR STATE'S LAWS FOR FURTHER DETAILS.
I AM NOT RESPONSABLE FOR ANY MISUSES/ MISTAKES CAUSED BY YOU WITH THE TASER-GLOVE !!!!
Step 1: Materials:
You will need:
An old glove, and the circuit from the picture.
You can get that circuit from an old disposable camera.I have found lots of them at yard sales for prices variating between 1$-4$.
Here is a tutorial (not my tutorial):
Step 2: Checking the Components....
Picture of Checking the Components....
Now you should check the transformer and the capacitor by installing the batteries and activating the circuit (it is a good idea to install a switch at the positive terminal of the batteries so you can activate the circuit when you want).
Connect the leads of your multimeter and wait for it to charge or untill it reaches 200 volts. If you used 1.2 volt batteries it should work fine.
BTW if you use this taser at 300V you will cause skin burns, it is good for self defence. :}
Step 3: Construction
Picture of Construction
Now you connect the wires from the metal bars of the glove to the leads of the capacitor, like in the picture.
Step 4: Now You Have a Taser-glove :DDD
Picture of Now You Have a Taser-glove :DDD
All you need to do now is to mask the components however you want, i have used some black electric tape in the past but now i didn't have any so i could not mask it for you... Sorry !
Put your imagination to the test.
I hope you enjoyed this project, if you like it dent for it !!!!!!!!
Nyxius (author)2016-02-11
As far as voltage goes, the voltage isn't dangerous. In fact the amperage is the real danger. This uses an armstrong resonator to increase the voltage. As such the amperage is very small and mostly harmless (even if somewhat painful). Disposable cameras operate at voltages under 400 volts and the capacitor is likely rated for only 200 microfarads. This will give you about 320 watts of discharge power over a 10th of a second. This much current will mostly travel over your skin to ground and not be a serious danger to your heart. However, it will make your nerves tingle for awhile.
pityukecske (author)2015-11-01
I wouldn't use just the leather of the glove as an insulator between me and several hundred volts spikes..being determined to step up against a bully is all-right, but stuttering like the scatman while doing it will take away a little from what you're trying to do..
Nice start, though! Congrats!
Ene SIlvian (author)pityukecske2015-11-03
Thank you, if you want to be a bit more protected you can use a double layer of insulating tape.
Experimental madness (author)2015-10-08
cool i really like the idea of use and the way you made it :D
First instructible? good work!
Thank you very very much !!!
About This Instructable
2,777views
42favorites
License:
More by Ene SIlvian:Simple Diy Vacuum Pump (diaphragm)Diy Cheap Arduino Compatible Flex/bend Sensor Made Without Static Bags, Out of Household Items :DTaser Glove :D
Add instructable to:
