Step 3Modifying the circuitry
Steps:
1. Unsolder the indicator LED, solder 2-3 inch wires to each of the LED's leads, and solder those wires back into the circuit. Simply put your just making a little extension cord for the LED.
2. Unsolder the capacitor attach short wires to each of its leads and put it aside for later.
3. Using a small piece of wire, bridge the switch that is used to charge the capacitor, so it will always be on.
4. I have finally replaced step 4 with a schematic
5. Solder in 2 10in. wires connecting them to the 2 wires you just soldered into the board. These wires will go to the fingers of the glove.
So you have the camera circuit in the center
The led hangs off to the right.
Under it is what? A wire leading to the battery holder, and the push button switch???
Then two wires run to what? The push button or the toggle switch? And the other line running to the other toggle switch? In between the push button or toggle switch, and toggle switch is the capacitor? And from what do you run the wires off of that will go to the fingertips?
Please help D: I have asked advice from two different people who work with these kind of things, and they don't understand it.
can I just leave the led as it is?. and is it possibl to wire the tazer to coin on the glove? thanks!!!!!!!!!!
ps. this is due tmr.. so please get to us as soon as possible!! >"< thanks!!
well maybe it would kill some1...
Also, im not much of an engeneer, this is my first prodject and im not that familiar with some electric stuff, I do however know my resistor codes. but making a circuit diagram was quite tought for this
0---------switch-----------
[] [] capacitor
