Step 4Making the final package
Steps:
1. Drill 4 holes on the top of the project box. 3 for the switches and 1 for the LED.
2. Glue the AA battery holder to the side of the project box, and drill 2 holes into the box for the wires from it.
3. Drill 2 holes on the side of the box for the wires going to the fingers.
4. Insert the different switches into each hole and securing them, make sure that the two switches for the capacitor are next to each other. (In the photo it is the two on the right)
5. Solder one of the wires from the battery holder to the remaining unused switch, then take a short length of wire and solder it from the other lead on the swtich to the correct polarity of where the battery was connected on the circuit board. Take the other wire from the external battery holder and solder it to the opposite polarity. It is a good idea to unsolder the metal clips from the circuit board that were used to hold the battery, and then solder the wires into the holes they were in.
6. Glue the LED into its hole, above the main power switch.
7. Feed the two 10 in wires through the holes on the side.
8. Put the circuit board inside the project box, and close it up. It will probably be a very tight fit, you may even need to trip down the sides of the board.
9. Check to make sure no wires are bridging, if they are wrap some electrical tape around them.
10. Close up the box.
8
comments
Add Comment
Add Comment
