Introduction: Tea Brewing Temperature Calculator
Picture of Tea Brewing Temperature Calculator
To fully enjoy any cup of tea it is important to use the correct temperature of water depending on the type of tea. If you don't have a temperature controlled tea kettle or don't want to have to measure the temperature of the water every time, one little trick is to mix boiling water with cooler water to get water at the desired temperature. Using the provided spreadsheet and your tea water source temperature you can have the perfect cup of tea every time.
Step 1: Measure the Temperature of the Water Used to Make Tea
Whether it is water from your sink, Brita filter, refrigerator, or wherever, use a thermometer to measure the temperature of the water which we will call the source temperature.
Step 2: Download the Spreadsheet
Step 3: Open Spreadhseet and Insert Data
Picture of Open Spreadhseet and Insert Data
Add the temperature of your source water and the size of your brewing container (mug, teapot, etc.) to the spread sheet.You can also change the brewing temperatures of the tea to match your preferences.
Step 4: Add Source Water
Picture of Add Source Water
Based off of the type of tea you are brewing, add the source water to the mug or teapot. You can either measure out the amount of source water needed (given in ounces) or use the percentages give or the chart to estimate the amount of source water needed.
Step 5: Add Boiling Water and Brew
crank_girl (author)2014-11-28
I'm getting a fancy thermopot where you can set the temperature that you want the water heated to so this is really handy. Thanks!
seamster (author)2014-11-26
I had no idea there were ideal temperatures depending on type of tea! Who knew.
Thanks for sharing this info!
About This Instructable
544views
8favorites
License:
More by wbrennan899:Tea Brewing Temperature Calculator
Add instructable to:
