3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
TeaLED: Led, Switch, Box and Batteries (not glue nor solder)
Step 2Cut and Fold
Cut and Fold
Cut the template paper and tape it to the cutting mat on the opposite corners, then cut a piece of the Acetate sheet and attached with tape on the other opposite corners.
- Mark the folding lines with the unsharpened knife and the ruler.
- Mark the 2 holes for the led's legs. and cut the line for the switch.
- Cut the template with the sharped knife and the ruler.
- Don't forget to cut the piece of plastic for the tab switch.
Start folding the template, but don't fold it completly, because we need to insert the led, the 2 batteries and the plastic tab that functions like the switch.
4 comments
Oct 12, 2010. 4:50 AMmissgroves says:
i'll probably use this to make a battery box with a switch at some point. it is simple as most brilliant ideas are.
When i can't get acetate to play with i laminate an a4 laminating pouch and it is about the right thickness and flexibility.
Nov 28, 2009. 8:22 PMFireslash892 says:
how exactly do we open the pdf? i think u use a software from adobe that  hav to pay for
can u just post an image of the template on google or sumthing....
also where did u get the plastic?>
Apr 20, 2009. 4:22 PMgreensteam says:
Could you provide a pdf with the template so we can print it exactly right?
Apr 21, 2009. 3:55 PMgreensteam says:
Many thanks. That is really clear now.
Apr 28, 2009. 7:00 PMmman1506 says:
what did she say it was removed
Apr 30, 2009. 2:58 PMbrizzx32 says:
Hey Becava got a suggestion. This would be a good Idea. To make a version of this to try to fit one of these on a light bulb socket and maybe step it down to make a miniature Light bulb that is hard wired that you can just screw on and would be able to turn on with the light switch instead. Just a thought
Apr 29, 2009. 4:55 AMmman1506 says:
sory my mind just linked the nickname to she
Apr 20, 2009. 9:04 PMthreecheersfornick says:
Yes, please!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:becava
