3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
TeaLED: Led, Switch, Box and Batteries (not glue nor solder)
Step 5Turn it on and off
Turn it on and off
Now pull the flap switch, and be sure the led is on.
To turn it off, push again the flap switch inside the box.
In case the led doesn't illuminate, check if your folds are correct, also that the position of the batteries are as the images below. Be sure the led's legs make contact with the batteries, check if the legs are correctly folded and in the right place.
4 comments
Oct 11, 2011. 4:56 PMnhora martinez says:
tu invento es super, te felicito
May 24, 2009. 4:13 AMBraisedDuck says:
Ummm.... I'm a bit confused, in what way does the switch makes the led light up? I don't really get it.Pls Reply me
May 25, 2009. 2:16 AMBraisedDuck says:
Thank you so much.
Apr 30, 2009. 9:43 AMmr. natural says:
WHAT A SWEET LITTLE LED LAMP! I will save this to use in some of my assemblage art work as I have a whole box of large white LED's to fiddle with! Thank you!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:becava
