Team Ladybirds - Wind Turbine Project
 by teamladybirds
Step 2: Transmission - Step 2 - Laser cutting
For the transmission, we need something to keep it all together. We chose to use Perspex as it is strong rigid, easy to cut and viewers of our turbine will be able to view the inner workings of it easily as it is transparent.
3 rectangles of perspex were cut using the laser cutter
- All contain 4 6mm holes at each corner and 2 4mm holes in the centre and centre top
- A large hole was made for the motor on 2 of the rectangles, size varies with motors but ours was about 35mm in diameter
The spacing of the holes was measured using the radius of the gears used.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
