Tear-away Goat Pants
5,165
74
13
Posted in CostumesAnimals
Introduction: Tear-away Goat Pants
About: I work at Pier 9 Workshop. I make videos about the Pier and our Artist in Residence Program. Check them out here: https://vimeo.com/channels/pier9
Pants are great! But so is freedom. Maybe you want to wear pants in the morning and maybe you want them to be goat pants. But up until now you had to stick with those decisions for the rest of the day. NO MORE!
I present to you tear-away goat pants.
I made these for myself and two of my friends because we are going to be fauns this Halloween. I wasn't sure what size they were so I decided to get a lot of help from using velcro. And man was I pleased with the results!
Let's get started!
Step 1: Materials
  • 1 yard goat pelt or goaty fur fabric
  • 2 1/2 ft of 2" width velcro tape
  • 2 1/2 ft of 1" width velcro tape
  • Sewing machine and thread
  • 3' of thick twine or rope
  • 4' of medium twine or nylon string
Step 2: Cut Out Pattern
I found a really basic shorts pattern on google images and eyeballed it. I cut the yard of fabric in half - each half will form one leg of the shorts. One thing that happened by accident but turned out super nice was that I made these with the fur pointing upwards. It protrudes out better if its upside down like that if it's long fur fabric - but that's all up to you.
The two looping cuts go in about 7" and down about 14". I eyeballed it. These aren't Ralph Lauren shorts! You won't get voted off Project Runway. They're tear-away goat shorts! Be bold with your cuts and don't look back.
If you decide to do a smaller cut on one side, flip the finished side fur up on top of your other half of fabric to use as a stencil. That way they'll be mirrored.
Step 3: Stitch the Butt
Start by sewing two mirrored sides together from the top down. I think I chose the slightly smaller curved cut sides as the butt but I didn't really know if that was the right choice. It worked.
I hand stitched at the beginning as you can see in the first picture. That's because I hadn't learned how to use the sewing machine at that point. If you don't have a sewing machine it probably won't take that long to hand stitch these whole shorts. I had to make 3 pairs so the machine was really nice to speed things up.
Anyways - stitch all the way down the curved line down to the crotch. Leave the legs unstitched. Leave that to the velcro!
Step 4: Add Drawstring
Even though these shorts are tear-away, I added a belt for a little extra security. They would work without it though if you're one of those people who wants to be able to tear them away at a moment's notice (and I hope you are!).
Measure out some twine long enough so you can tie a knot with it around your waist like a belt.
Wrap some gaffers tape (the best tape) around the tips so it won't fray.
Tape twine down to top of shorts so it stays put. Then fold fur about an inch over twine to create a channel. This will be your drawstring.
Sew the channel being very careful not to sew twine into the stitches. If you do it won't be able to tighten!
Step 5: Sewing in the Sweet Stuff (velcro) Pt. 1
Start by just measuring about 10-12 inches of the 2" wide velcro for each of the back of the legs. This will go on the fur side. Cut the lengths and then just stick on for now. Then cut a 14 inch length of the 1" wide velcro and stick along the front seam on the fur side.
Now you can stitch the velcro on with the machine or by hand. If you are using a machine the needle may get gunked up from the adhesive from the velcro. Clean this out often because it will mess stuff up.
Step 6: Sewing in the Sweet Stuff (velcro) Pt. 2
Measure out and cut two 8-9 inch lengths of the 2" velcro and stick to the outer edges of the non-fur side of the fabric. Then cut out a 14 inch length of the 1" wide velcro and stick it to the non-fur side of the front seam. Now stitch it all on! If you are seeing the the seams in the fur don't fret. If you pick at the fur around the seems you can hide them.
Step 7: Adding Optional Leg Drawstrings
I added small channels at the bottom of the legs and threaded through small nylon strings so that I could tighten the shorts at the bottom. I threaded through with a knitting needle. Totally optional.
Step 8: Fini!
    • Woodworking Contest
      Woodworking Contest
    • Flowers Challenge
      Flowers Challenge
    13 Comments
    how did you make the feet? You look awesome btw!!
    I love everyone's comments! I'm so thankful I wasn't alone in my feelings about the restrictions of non-tear-away goat pants. Check out final costume!
    If you're going to own a search term, you really want it to be something like "tear-away goat pants."
    Your turn in that GIF is spot-on. And the final costume turned out great! Solid work.
    epic. i wanna party with you!
    These are awesome! For so many years I have been held prisoner in my regular, step-in, non tear-away goat pants. And now you come up with a solution that is so simple, yet so brilliant... Bless you!
    oh my goodness this just made my day! I love you for doing this Instructable :D. I often think to myself "You know this wardrobe would really benefit from some tear-away goat pants!"
    Thank you! Thank you! Thank you! Finally I can be quickly liberated from my goat pants. ;)
    That's awesome.
    I'm just gonna come out and say what we're all thinking: Tear-away goat pants should be standard issue uniforms in most professional and administrative occupations.
    Am I right, or am I right?
    I wasn't a big fur person before but now I that I've tried it out I couldn't agree more!
