Take a nickel and hammer it out. Make sure to hammer on a smooth surface with a smooth faced hammer. Other wise you'll end up with deep gouges that ta...
Starting with 500 grit sand paper start smoothing out the teardrop. I found it eaisier to place the sand paper on a piece of carpet and rub the teardr...
Take a nickel and hammer it out. Make sure to hammer on a smooth surface with a smooth faced hammer. Other wise you'll end up with deep gouges that take alot of sanding to remove. The smoother the coin is in this stage the less you will have to sand in another.
Where did you hammer out the nickel? Like, what kind of environment. I tried doing it in a basement with a penny, and I only managed to get it slightly flatter and slightly larger before I couldn't take the ringing in my ears and was afraid to chip a hole in the concrete floor.
In order to flatten a coin you have to hammer it between two surfaces that are harder then the coin itself. The hammer is one surface. I use an old sledge hammer head for the other hard surface. Conrete will just absorb the impacts from the hammer blows. Don't forget to wear ear and eye protection.
Thanks SO MUCH for this instructable! While mine didnt come out quite as perfect as yours did, for my forst attempt it turned out pretty good! Hopefully my friend will like it when she gets it!
When the trail end of the tear drop is clamped in, you can bend it around the drill bit to form that loop. When I did it I used a small hammer and tapped it around.
I want to Engrave a treble clef into the front, does any body have a suggestion on how to go about it? I have a Dremal and a bench grinder. I 'm looking for techniques here
This takes practice but it's do-able. Print out the right size treble clef onto computer paper. Cut it out and super glue the image onto the pendant. Use a diamond burr bit to gently remove the treble clef image until you've engraved it. Remove the glued on paper with light sand paper and continue to clean up the image with the burr. Good luck! Don't forget to post a picture.
I had a go at this myself- not 100% happy but still good for my first go I think. And i didn't stick to the lines I drew perfectly so it's not symetrical. I Drew the design freehand anyway so it would never have been great cause i didn't draw it symetrically in the first place. Take a look if you like :p
I used a piece of pine. But any soft wood should do. You may want to try hammering the carriage bolt on the wood first to make the indentation and then place the piece of metal over that for hammering.
I have been making RINGS from coins for a while. Never thought about this or some of the other ideas such as the locket. Gonna definitely give those a try.
No.... It is NOT illegal to deface coins BUT they can no longer be used anywhere for currency or you would be breaking the law. It is perfectly legal to drill a small hole in a nickel, paint a quarter, or bend a penny if you want. But you cannot use it to help buy that new video game or drop it in a Coinstar machine! Coins that have been defaced are only good for keepsakes or can only be sold as novelty items. So you got a two-headed quarter from the gas station, every person that keeps using that quarter as currency would be breaking the law since it was not minted like that and somebody defaced it to be a novelty item.
According to U.S. code Title 18, Chapter 17, Section 331:
So if i don't have a convenient sledge around, what would you suggest using for an anvil? I'm trying the cement floor of my garage, but if you have a better suggestion it would be great. Thanks!
Here is one that I made yesterday. After cutting out the shape and filing it, I didn't really have enough material left over on the top to fold over so I just superglued a bent bit of paperclip to pass the string through. If it falls off later I'll have to solder it, but I don't use lead-free for electronics and didn't really want to buy any at the time. Thanks for the great instructable!
You would have to be careful if you start selling them. I believe you can do whatever to a coin, unless you do it for payment. I'm not sure what the exact laws are, but I'd check before you sell them.......
Thank you Mr. B for sharing your techniques, knowledge and creativity! The piece is very attractive and inspired me to spend a couple hours in the shop making one for my wife for valentines day. It tuned out nice so I had to give it to her right away. She loves it. I've never commented on an 'ible before but now that I see you can add an image too I'll do it if you want to see my finished product. I also checked out your ring making 'ibles and suppose I'll have to try one of those too! Thanks again for taking the time and effort to share....much appreciated!
Thanks a million. I would love to see what you made, please post it. I think it shows folks you don't need special tools or know how to make something nice.
Keep the light in your shop on because I'm posting a new instructable soon. It's taken me about 20 hours to figure out the process but it'll be worth it when I know someone actually made it.
LOVE. I'm still hunting for a pre-1965 silver quarter to make the ring instructable, but no luck; even my old coin collection has gone missing! Anyway, I want to make this. I also thought it could be a very pretty copper necklace out of an old (real copper) penny.
Alright, here's my attempt. I don't have any polishing compound and the highest grit sandpaper I could find was 600, so I'll probably make a trip to the hardware store.
My dad found some 0000 grade steel wool, so I polished it with that. I also made a second attempt, which has a few more scrapes, but is better formed. I'll be making a third shortly to try to make it perfect. Now all I need is a chain, and I've got a great Valentines present!
Love this post, i am stationed in afghanistan for the next few months as this would have been perfect,,,, if I had not just sent my dremel tool home. sigh. I will have to find something else to polish it with.
no it its ilegal to make these from any coin that is in circulation as currancy in the usa this includes foreing coins exchanged with us curancy. also any curancy destroyed or other wise made unusable must be reported to the mint dont confuse the use of the the word fraud at the begaining as pertaining to the whole of the law it is still defacing destroying or mutilating goverment property just because its in your pocet doesnt make it yours. it is the same as painting the side of a building just because it looks good doesnt meant its not vandalism
The Treasury's Letter to Vance Fowler Is it legal to press pennies or other coins?
Mr. Angelo Rosato reproduced this letter from the Department of the Treasury to Mr. Vance Fowler in his book "Encyclopedia of the Modern Elongated", (ISBN 0-9626996-2-4) angrospub@aol.com. The letter was dated July 22, 1980, letterhead: The Department of the Treasury, Office of the Director of the Mint, and is probably the source of many quotes collectors have seen over the years. It reads in part:
"This is in reply to your letter of Jun 20, 1980, concerning United States statutes governing the destruction, melting, or other extramonetary uses of United States coins. You refer to and question the legality of a souvenir machine which compresses coins and returns a souvenir. You refer to Title 18, U. S. C. sections 331 and 475.
As you are already aware, a federal statute in the criminal code of the United States (18 U.S.C. 331), indeed makes it illegal if one "fraudulently alters, defaces, mutilates, impairs, diminishes, falsifies, scales or lightens" any U.S. coin. However, being a criminal statute, a fraudulent intent is required for violation. Thus, the mere act of compressing coins into souvenirs is not illegal, without other factors being present.
Section 475, which you refer to in your letter, regarding the attachment of notice or advertisement to legal tender, does not apply to your souvenirs in this case. Your are not impressing or attaching a business or professional card, notice or advertisement to a coin, your are simply making an impression on the coin.
We hope this information answers your question. If we can be of any further assistance, please contact us.
penny presses and other devices you might find at amusmentparks ect have to report every penny they destroy and have prior concent from the gverment to do so http://codes.lp.findlaw.com/uscode/18/I/17/333
there are lengthy legal discusions about defacing curancy on the web
so tell me, how is it that tv channels like QVC get away with selling jewelry that they admit to being made with us coins? Point being, it's legal. It's only legal if it's for fraudulent intent.
i advise you to call the secet service office in your area and ask to quote the person i spoke with "destruction of genuine currancy in curculation is in fact ilegal" now i dont figure they will come smash down your front door if you make a few as they have several hundered cases that take pesidence but it doesnt change the fact
The key word in the statute is "fraudulently." If you are defacing coins for use in perpetrating fraud, it falls within the purview of the statute. The subject of altering coins into objects of art or souvenirs is not addressed by statute.
"Section 331 of Title 18 of the United States code provides criminal penalties for anyone who 'fraudulently alters, defaces, mutilates impairs, diminishes, falsifies, scales, or lightens any of the coins coined at the Mints of the United States. This statute means that you may be violating the law if you change the appearance of the coin and fraudulently represent it to be other than the altered coin that it is. As a matter of policy, the U.S. Mint does not promote coloring, plating or altering U.S. coinage: however, there are no sanctions against such activity absent fraudulent intent. (Source U.S. Mint)"
"If you are thinking this is illegal, your not the first.Section 331. Title 18, U.S. CODE: Prohibits among other things the fraudulent alteration and mutilation of United States and foreign coins. This statute does not prohibit the mutilation of coins if done without fraudulent intent or if the mutilated coins are not used fraudulently. This now Lehman Law was written only to protect the silver content of coins back when coins actually contained silver and the government actually invested in the circulation money."
Ah, I suppose you googled "Lehman Law. " I don't know who the author of the quote was referring to, and my google and wikipedia searches were unproductive as well. I presume it refers to the author or sponsor of Section 331. Title 18, U.S. CODE, but I found no confirmation of that supposition. I suggest you contact the author of the quote at http://www.coincutart.com/servlet/StoreFront for the answer.
The most important part my original post is: "As a matter of policy, the U.S. Mint does not promote coloring, plating or altering U.S. coinage: however, there are no sanctions against such activity absent fraudulent intent. (Source U.S. Mint)," ("no sanctions" means there are no penalties such as fines, imprisonment, censure, reprimand, seizure of the altered coins, etc.) See the very last paragraph "Is it illegal to damage or deface coins?" on this U.S. Treasury Dept. web page. http://www.treasury.gov/resource-center/faqs/Coins/Pages/edu_faq_coins_portraits.aspxhttp://www.treasury.gov/resource-center/faqs/Coins/Pages/edu_faq_coins_portraits.aspx
An example of fraudulent activity would be alter a quarter (painting, plating, or stamping or engraving) to resemble a dollar coin and passing it off as a dollar coin thus defrauding the seller. Another example would be to plate a dollar coin to look like real gold and passing it off as a "proof" to a collector thus defrauding the collector. Another would be to pass off a two-headed coin made by gluing or fusing two coins together as a rare "mint mistake" to collectors, thus defrauding the collector. Actually doing any of these examples would make you guilty of two crimes, violation of Section 331. Title 18, U.S. CODE (altering coin for the purposes fraud) and fraud in the act of the selling. Altering the coins for purposes of fraud is a violation only of Section 331. Title 18, U.S. CODE, but I would think the fraud would actually have to be carried out to prove the intent of altering with intent to defraud.
I have been making different object for years. I sell some of the finished items and just in case of any problems with destroying legal tender, I went on eBay and purchased coins that are no longer legal currency. For example when Israel changes their coins after a certain time the old coins are no longer legal tender. I bought about 50 different size and made from different color metals for $10.00 including shipping. I live in Canada and am unsure of our laws here and I was never able to find anyone who commit to an answer regarding the legality if reworking coins so to be safe I use these other coins. Since I have done different things to hundreds of coins I just wanted to be sure. This is just another option you might want to look at.
I live near the Canada/U.S. border, and in certain tourist areas those coin crushing machines are numerous on both sides of the border. I have noticed that most of the machines on the Canadian side have U.S. coins waiting to be crushed, and conversely the U.S. machines have Canadian coins waiting to be crushed. This is not to be confused with the collected coins people pay to use the machines, these are held separately. This may just be a strange coincidence, but this leads me to think that it may not be illegal to destroy a foreign currency. Just food for thought.
Using a coin that is valued at 5 cents but costs the government 9.22 cents to make may seem trivial, but knowing that the cost of this coin and the penny exceed its value should be a reminder that we should empty our penny jars often. Otherwise our tax dollars toward minting new coins. So, yes it is technically illegal, but also unpatriotic.
With that said...it really is a cool little project.
Coins are minted regularly regardless of the amount of coins in circulation, they make new coins and hold onto the older ones, so your tax dollars are being used to mint new coing anyway. Besides, as people have said correctly in pretty much every instructable with coins or bills, It's not illegal to deface currency as long as you don't try to circulate it again, and I don't think you can buy bubble gum with a peny turned into a teardrop. And I don't think it's unpatriotic, maybe stupid, if coins weren't minted anyway, but why unpatriotic? I think it's less patriotic to go around the internet makig stupid comments, therefore making people arounf the globe think USA people are jerks. I' not talking about you, your comment was well written and expressed your ideas in a non-trolly way, but "americans" are generally very cocky when they're online and come out as...not pleasant people to have a conversation with
Last I checked, as long as you aren't selling these you can make them into jewelry. It is illegal to deface them just to deface them, however making them into jewelry is a whole nother thing. Penny presses turn your pennys into souvenier coins with completly different images on them and if you have ever seen old jewelry channels they sometimes have necklaces and rings make out of coins. And Owning or making this is not illegal.
actually it is most definitely illegal. see http://frwebgate.access.gpo.gov/cgi-bin/getdoc.cgi?dbname=browse_usc&docid=Cite:+18USC333
However like I said in my previous comment, I don't really think the feds are going to kick down your door for making a pendant. I dont know about an instructable. But definitely wouldn't try to commercialize or sell.
your link takes me to this: "Whoever mutilates, cuts, defaces, disfigures, or perforates, or unites or cements together, or does any other thing to any bank bill, draft, note, or other evidence of debt issued by any national banking association" so no info on money. AFIK, It's illegal to deface US currency fraudulenty, ie: in order to make a profit by turning it into another piece of currency. This clearly isn't trying to be another coin, so I think the writer of this instructable is in the clear.
uh no.. where do you get that it has no info on money? you cut the entire ending of that sentence out of your paste, which included words like "Federal Reserve bank, or the Federal Reserve System" which is kind of important info :)
Here, let me translate for you. it says:
"[if anyone]" .. "mutilates, cuts, defaces, disfigures, or perforates, or unites or cements together, or does any other thing " .. "to render such bank bill, draft, note, or other evidence of debt [read: coins] unfit to be reissued"..
Basically it says, you smash, cut, melt, dye, or drill a coin or bill, it's thus "unfit to be reissued" and thus violates that law.
"This statute means that you may be violating the law if you change the appearance of the coin and fraudulently represent it to be other than the altered coin that it is. As a matter of policy, the U.S. Mint does not promote coloring, plating or altering U.S. coinage: however, there are no sanctions against such activity absent fraudulent intent. "
So, if your intent isn't fraudulent, you're golden
Your quote is from: http://codes.lp.findlaw.com/uscode/18/I/17/333 and refers to paper instruments only, not coinage.
Probably the most popular bit of artistic "mutilation" would be to fold a paper bill into a wearable finger ring. As a practical matter, I doubt the Feds will spend tens of thousands of dollars to prosecute you if you were to tear up or burn or spindle or mutilate the odd bit of paper currency. When you have purposefully destroyed a million dollars or so of paper currency, I suppose they might be interested, although you would be out the million dollars or so, so maybe the crime is its own punishment.
Man I wish I could do these sort of things for my girlfriend. Sadly she is allergic to certain metals like nickel, so I have to really watch what I get her
haha wow, me too man, for instance most belts are nickel, i had to buy mine especially, anywho, nickls arnt made of nickel =) there zinc, idk if shes alergic but maybe not, good luck
Not quite correct, the nickel is still made out of nickel, they just add copper to it to make it non magnetic. pennies have a zinc core, nickels would be too soft and reactive if they were mostly zinc,
Why not try BONE CARVING? The process is the same (more or less) and the results too! It gets ad smooth and shiny as glass I've done some and they where all way appreciated.
What did you use for the chain, and where did you get it. I really like the end result. I'm thinking about making this just for the heck of it, though my girlfriend might like it. :)
It's a silver chain my wife has had for years. You can buy one at a jewelry counter but I usually go to a craft store. They sell silver chains for under $10.
I bet something very similar to this with a treble hook on it would work rather well as a fishing spoon. or attached to a spinner bait. Nothing can be more satifying than catching fish with something that you made yourself. Great instructible!
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Here I show my earring drop, I hope you like it
Best regards from mexico. thanks
http://www.thecoinsmith.com/THECOINSMITH/HOME.html
thanks
It's just a couple of ball peen hammers. One is homemade but there's nothing special about it. Good luck.
Bass Teardrop Pendant
I hear there's a site called "etsy" where people sell stuff they make. I'll check it out and let you know if I get it going.
I have to ask: do you have any plans for the metal pieces left behind when you cut out the center for the pendant?
202-354-7227
it is not illegal to turn money in to art or jewelry. it would be illegal to try and make a dime look like a quarter and try to pass it off that way.
i sell $20 bills with peoples kids and pets on them but if i tried to buy something with them then i would be breaking the law.
Sincerely,
Kenneth B. Gubin
Counsel to the Mint.
Believe in Google, Punctuation and Spellcheck.
http://reviews.ebay.com/CUT-COIN-Jewelry-Is-Coin-Cutting-Legal-OK-or-Illegal_W0QQugidZ10000000001433735
http://www.parkpennies.com/pressed-penny/penny-pressing-legal.htm
I Googled your spelling, and found nothing pertinent; just ads.
Actually, "Lemon Law" doesn't apply here, either.
I think you mean "Blue Law," meaning an outdated law or ordinance.
for the answer.
Specifies paper currency, not coinage.
however I dont think you'll have any feds kicking down your door, unless you start doing this on a commercial scale
association"
Cheers
http://www.instructables.com/id/Carve-A-Traditional-Maori-Hook-Necklace-From-Bone/
(not mine)
Nice Instructable, cool project, and brilliant transformation of a nickle into jewelry. Nice work : )..
You do very nice work!
Bet, your a jeweler!
