Teardrop Travel Trailer (added VIDEOS!)
 by Rob O
FeaturedContest Winner
Step 22: Paint the floor. Attach the walls.
First thing I did was to put several coats of porch paint (green) on my floor.  Some folks use linoleum or  adhesive tile or whatever.  I was fine with a couple coats of primer and a couple coats of paint.  I knew that I would rarely see the floor bc the mattress would be there.
Next I attached the walls.  I screwed in through the base of the wall into the 2x2 subfloor.  This created a really sturdy joint.  I used some pieces of ply as braces to hold the walls  up.
I temporarily braced each wall with a couple of spars across the top.   The tiny registration holes I drilled through BOTH sheets of ply while they were still sandwiched were a HUGE help here to get things lined up.
Next step was to attach the inner skins.  I line them up and glued and brad nailed to the spars.
Its starting to look like a trailer!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
