This Tech. demonstration is to raise awareness that laptop batteries can easily be replaced with any other kind providing it is of correct, or sufficient, voltage. Here I am using two 6V. batteries rigged up to provide twice the voltage to power a Compaq Armada 110.
*Depending on your laptop warranty this may void it!*Before reading this Instructable, I recommend reading this one first!!For this you will need to take your old laptop battery apart, The battery I used was very stubborn and I only got it apart with considerable cosmetic damage, For taking it apart try starting by the contacts where the battery connects to the laptop, I have not got any proper pictures of this step as I did it about 1 month ago, and I only just un-earthed the battery casing, Once you have got a little bit of the battery casing prised up things will either be easier or a bit more difficult, the Compaq battery was fused together so I was practically just breaking plastic!
After you have got the battery apart you will find around 9 battery cells depending on the type of laptop battery. You will need to rip all these chunky batteries out, making sure not to rip the wire leads to the batteries off the circuit board (pic. 2)
The "Hot knife" supplied with these types of gas soldering irons usually does not work as well. It should be a thin, flat knife. It is actually less painstaking than using a dremel.
If you happen to touch them with a thin hot knife, they are NOT going to explode.
The cells does not contain free gases such as hydrogen, as some old lead batteries would give off when overcharging. Now - THAT could be really dangerous to light a flame around!
i had just disconnected it and reconnected it and it still boots up from the batt
I know what i am talking about,because i see it right before my very eyes.
I will even put a picture up if you want.
That would also be a really badly engineered because some time in a laptops life the battery will drain to the point that its not enough to keep the key in.
No one has the guts to do that with a macbook air,right?
Also,ALL BATTERIES SELF DISCHARGE
QUOTE WIKIPEDIA:Self-discharge rate 5% month
So it self discharges 5 percent a month,so say its 20 percent charged when it not enough to power a laptop.
Give it a good five moths and your theory will burst in flames,Try it i will bet you 20 bucks if it does not work afterward (the circuit board)
So if someone at an airport discharged it to 15%,Then did not charge it for another 3 months or so does that mean that they have to buy another battery,no.
But seriously,batteries WILL discharge to the point that key will be lost
Yes
I found 8 nimh cells
yes there was a circuit board
Yes i have disconnected it
Hmm,whats that you say...no? Exactly.
I think it would be cool if you could remove them and fix a suitable transformer straight through the battery board instead of using the DCin Jack.
We have a laptop in which the DCin has broken and the board has got damaged in removing it or maybe when it was dropped. Any thoughts on how to sort it to at least make it useble? The machine still runs off battery power but the battery cant charge via DCin through the motherboard anymore.
DO NOT ALLOW YOUR LAPTOP TO CHARGE ANY BATTERY THAT ISN'T LITHIUM ION!!!
I learned this the hard way when it made my sealed lead acid battery make bubbling noises and expand some on one side! Just be safe, once you have hooked up your homemade battery and your laptop recognizes it, unplug the laptop's charger!
Thats all I have to say, and again, kudos on this Instructable!!!
I would suggest a high degree of caution with this stuff though. Lithium-ion battery cells can explode (or spew fire) really easily if not handled carefully, even moisture from your skin or even high humidity can cause this to happen.
I'm guessing by the mere fact that you opened it is why it won't boot with the battery w/o the PSU in. That little board you wired up the new cells to is very picky and designed to kill the battery all together in most cases of any kind of tampering because of how volatile Li-ion cells can be. When replacing the cells it can sometimes take 2 or 3 charges before it gets back to normal. But as long as the voltages are the same as the OEM one it should "work" but the computer may not be able to see the charge level and may not be able to charge it at all.
Older computers may not all have Li-ion's in them, but if you are reading this and thinking of replacing your laptop cells instead of buying new, I'd recommend also reading this guide.
http://www.electronics-lab.com/articles/Li_Ion_reconstruct/index_3.html
Great work with the mod. Is it still working? Did you figure out a way to charge it?
