Step 3Removing the bottom
Make sure you've removed your 7" aluminium puck from the turntable before turning it over and placing it on it's back (on the dustcover, a pillow or something else protecting the tone arm).
Unscrew the four feet by twisting them like a regular screw. Remove all screws (don't forget the screws located under the feet). Please make a note of which screws that go where as there are three different types and store them separately.
Double check that all screws are removed and then try to get a grip of the bottom by placing your nails between the bottom and the top. The bottom is made of a relatively soft rubber or plastic material so it will flex a little. It will take some force to remove it. Let the cable slide through the hole in the bottom so you can remove the bottom entirely.
Add Comment
