3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Technics SL-1200/1210 pitch slider replacement and adjustment
Step 4Removing the pitch slider
Unscrew the two phillips head screws at the top and the bottom of the pitch slider PCB. Notice that on the top there is a small grounding cable that is fastened with the screw.
If the pitch slider has not been replaced earlier the cable (You did disconnect the pitch slider cable in step 2 didn't you? Otherwise you will have to go back) going to the main PCB will probably be fastened in a small metallic spiral. You will have to unwind the cable from this before you can get the slider PCB loose, but do not just pull it! If the slider's been replaced earlier it's possible that it's not fastened as it's a bit of a hassle to do without opening the turntable even more.
Now you should be able to remove the pitch slider PCB.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:krakpot
