3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Technics SL-1200/1210 pitch slider replacement and adjustment
Step 6Attaching the new slider
Insert your new pitch slider in the holes where the old one was seated. It's only possible to mount it one way, make sure all legs go though the holes and that none are bent. If you can not get all legs trough there's probably too much solder left in the holes.
Make sure all legs go in as far as possible. To make sure the the slider stays seated while soldering you can twist some or all of the legs slightly. Solder all eight legs properly.
Turn the PCB over and twist the metal sheet back to the original location. If you did not desolder the LED; make sure the two legs do not touch each other.
Replace all three screws, don't forget to replace the metallic washer between the epoxy and metal when reseating the LED screw.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:krakpot
