Techniques for Foolproof Sous Vide Burgers
1,028
6
Posted
Introduction: Techniques for Foolproof Sous Vide Burgers
Unless you're a line cook or you have lots of experience cooking burgers, it's difficult to get consistent, juicy results. Couple that with the increasing use of low-fat ground meats (like 93/7 turkey or 90/10 ground beef) and it's easy to end up with dry, hockey-puck-like burgers. And no one wants that.
With the proliferation of low-cost home sous vide equipment like the Nomiku, Anova, and Sous Vide Supreme (as well as the multiple Instructables available for building your own), I'd like to share the techniques I use to get juicy, consistently sized, uniform burgers using a few easily found tools.
Step 1: Required Equipment and Materials
The equipment list is pretty straightforward:
1. An eight-ounce plastic burger press (I found mine at a dollar store), and I typically have 10 or 12 on hand to permit packing up bulk ground-meat purchases
2. A digital scale for portioning the ground meat
3. Vacuum bags compatible with your vacuum sealer
4. A vacuum sealing machine
5. Ground meat
Step 2: Measuring and Preparing
There are several ways you can portion the ground meat. Since the burger presses I found are sized for eight-ounce patties, they'll accommodate both four- and eight-ounce patties. The photos show the production of two four-ounce patties, but it's the same technique if you do one eight-ounce patty.
1. Place a measuring vessel (I used a bowl) on your scale and, using the tare function, zero the scale.
2. Place a four-ounce portion of ground meat in the bowl.
3. Take your empty burger press and grab a patty divider made from a thin cutting mat cut into a circle.
4. Evenly distribute your four-ounce portion of the ground meat into the bottom of the burger press.
5. Place the cutting mat divider (green, in the photo above) on top of the ground meat.
6. Measure another four-ounce portion of ground meat.
7. Evenly distribute the ground meat on top of the cutting mat divider.
You now have two four-ounce patties, ready for sealing.
At this point, I typically portion out all of my ground meat. If you want full eight-ounce patties, omit the cutting mat divider: It's your choice.
Step 3: Labeling and Sealing
Take the empty vacuum sealing bags and label them with the contents; date the bags as well.
Place the filled burger presses into the vacuum sealing bag, and seal.
Step 4: Delicious Variations
There are a multiple delicious variations that you might consider:
1. Goat-cheese Stuffed Burgers: Ever tried to make a cheese-stuffed burger? It's often difficult to keep them from bursting when you cook them traditionally, but this is a great technique for sous vide. Portion out four ounces of ground meat and place it in the bottom of the burger press. Then, portion out a couple of ounces of goat cheese, flatten it into a disc, and place that on the center of the ground meat in the burger press (be sure to leave a good amount of un-cheesed (is that a word?) space around the perimeter}. Portion out four more ounces of ground meat and fill the burger press, leaving the cheese completely encased in ground meat.
2. Carmelized Onion Stuffed Burgers: Use the same technique as the goat-cheese burger, but use cooked, carmelized onions.
3. Almost anything else you can think of, including pickles, giardiniera, roasted garlic, or sauteed mushrooms. Just remember that with sous vide cooking, temperatures are low so pre-cook the stuffings if you don't want them essentially raw (they'll certainly be warm, but most vegetables must be cooked at higher temperatures than meats).
Step 5: Tips for Cooking and Finishing
Once your burgers are vacuum sealed, you can either freeze them or throw them directly into your sous vide equipment.
If the meat is refrigerated or at room temperature, an hour to ninety minutes in the water bath will cook them completely; I wouldn't recommend cooking the burgers for more than around two to three hours.
If the meat is frozen, I add an hour to the above cook times; this enables the burger puck to thaw.
For lean turkey burgers, I set my water bath to 150 degrees Fahrenheit (66 Celsius).
For beef, I set my water bath to 135 degrees Fahrenheit (57 Celsius).
When the burgers are ready to come out of the bath:
1. Remove them from the bag and the burger press (remove the divider as well if you made four-ounce burgers)
2. Handle gently and pat them dry on both sides
3. Sous vide cooking doesn't reach temperatures high enough to produce the Maillard reaction. As the Science of Cooking web site says, "Browning, or the Maillard reaction, creates flavor and changes the color of food. Maillard reactions generally only begin to occur above 285°F (140°C). Until the Maillard reaction occurs meat will have less flavor." Thus, in order to brown the burgers, either hit them with a kitchen torch, or throw them into a smoking hot skillet. In both cases, this step should be very short (in a skillet, 60-90 seconds to brown them up). Any longer, and you risk overcooking your burgers.
Step 6: Final Thoughts
This approach yields uniform, juicy burgers and avoids some of the hassles others propose for sous vide burgers like pre-freezing patties on a cookie sheet before vacuum sealing. I hope you find this approach useful!
  • Gluten Free Challenge
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
3 Comments
I 100% agree with the pasturization process just was not aware ot could occur that quickly. Thanks for that link to the research. I enjoy reading research a lot, knowledge is power.
i love sous vide cooking and our family does it all the time. everything turns out amazing.
One concern is thr cooking temperatures you recommend in your ible. Everything i have read reccomends sous vide most all ground meats to 165 degrees for bacterial extermination. One exception is good quality ground up steak as it should be safer at lower cook temps.
Obviously that is just a precaution as people do eat hamburgers various temps and usually have no problems. I will say sous vide burgers at 165 are amazing also. so juicy...
Another thing I read about was pasturizing meat but cooking at low temps for long periods of time to kill bacteria.
Also a question... Do you leave the burgers in the press? When i sous vide burgers i put 1 or 2 in small bags and they dont fall apart. We have also bought the premade patties on sale and just put the whole pack in big bag leaving the wax paper that seperates the patties inside and cooking for several hours due to thickness (approximately 1 hour per inch) and they have turned out great. Put a little liquid smoke and some bbq right in the bag sometimes.
I leave the burgers in the press; both the burger press and the dividers I make using thing cutting mats are made of food-safe plastic and the temps for sous vide cooking are low enough that I feel comfortable with that. Liquid smoke is a great addition.
I hear a lot of comments about food safety concerns surrounding temperatures in sous vide cooking. I encourage you to read the excellent writing on the subject by Kenji Lopez-Alt at Serious Eats; the article can be found at the following link: (
http://www.seriouseats.com/2015/07/the-food-lab-co... He includes both a table and a graph using USDA data showing how sous vide cooking pasteurizes the meat.
As a former scientist, I'm comfortable with these data, but of course food safety is ultimately a decision for the individual.
