3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ted Baer's Bicycle Wheel Windmill
Ted Baer\
Ted Baer has created a series of small windmills designed for third world use over a period of three decades. This first in the series has evolved in simplicity and power. The aluminum vanes are constructed from a building flashing roll utilizing the pre-existing bend of the roll in construction. Two 16 " sections are riveted together to make one vane. The vanes clip on the spokes of the bicycle wheel using a "bent nail" and a bend in the vane. Detailed pictures will be provided shortly. The generator is a surplus permanent magnet motor and the uv resistant endless belting is purchased to length from online sources.
Output is a respectable 2 amps at 12 mph (18-20 volts) providing a cost effective alternative to a solar photovoltaic panels (if wind is available). The total cost of the windmill was less than $80 purchasing most items new (off-the-shelf). The two most expensive items were the permanent magnet motor (around $30) and the uv resistant round belting typically used in food processing plants to drive conveyors ($3 to $5 per foot).
The windmill does have a tail (see new photo). The frame is made from PVC pipe. It is important to use only a 24 to 27 inch rear solid axle bicycle wheel. The wheel is mounted to a PVC end cap via a hole drilled in the middle of the end cap.
The generator is a 24 volt DC permanent magnet motor. This one was surplus and used in old main frame disk drive units. DC permanent magnet motors are available through Internet surplus resources, but getting scarce. Here is a link that gives you more detail on sources and the types to look for: http://www.otherpower.com/otherpower_experiments_tapedrivemotors.html
The generator is mounted using a simple L bracket. Should be sturdy (not the typical shelf bracket) and both the motor and the bracket are secured with radiator hose clamps.
The windmill pole is electrical conduit that 1.5 inch PVC slides over. A short segment of PVC pipe is screwed into the metal conduit to create a bearing that the windmill pivots on (PVC to PVC).
The tail has to be counterweighted to balance the unit. Ted used a bunch of pennies and got it balanced perfectly. What else are they good for? :-)
I'm adding a couple of new pictures. Sorry we don't have more detailed steps with pictures. This was done some time ago.
Step 1Testing
Testing
The test rig is a Windstar van with top rack and platform. The tripod is a roof TV antenna mount. Windspeed, volts and amps are taken and recorded with a digital camera. Video clips will be provided shortly.
100 comments
1-40 of 100next »
Nov 22, 2011. 8:42 AMzipperboy says:
Looks good. The belting issue is a big one though. I was thinking if you used a double wheel set up where the distance between the 2 wheel/windmills could be adjusted, then you could find a combine or farm implement belt that would tie the two wheels as one with a simple loop. As large bike wheels are not going to spin at crazy speeds it might also be possible to make belts out of pre-stretched multiweave rope. As used by climbers. this would require gluing a rubber rim liner in, maybe x2 to get more grab. you would also need to learn to weave two ends together, however there are insructibles for that I am pretty sure.
Then using the rear chain drive gear as used with bike engine kits, on just one of the wheels you could tie the wheel set to the generator with bike chain. The upside here is you could likely use the front bike wheel on the side not attached to the chain drive as it will be taking less torque. For durability it might help to put a torque brace as used with high power electric bike hub motors on the chain drive side.
Still pretty all right at is , good work, Phil aka zipperboy
Sep 13, 2011. 1:24 AMComputothought says:
Cool...
Jul 23, 2011. 4:56 PMkattorres says:
What amazes me most is that you have built this out of items that can already be found in most impoverished areas. This is a great thing to get some church groups, environmental groups, youth groups, etc. interested in sponsoring. I would be interested in having someone teach a group of our church members how to construct these, then send them on missions annually. We have sent members to the Bahamas in the past for medical missions and house building, but the problem is getting the supplies necessary to remote locations. You have to carry EVERYTHING you are gonna need to build with, in with you. Alot of times the villages can only be reached by foot. So anything you can actually build out of materials found ON LOCATION is very helpful. Thank you for sharing your knowledge.
Apr 9, 2011. 5:09 PMchrisnotap says:
I love this instructable. Great idea to make the blades that connect easily, quickly and stay put. You have gotten my brain juices flowing to make a similar unit. Love the Honda wago-van. A great little car!!
Feb 16, 2011. 8:34 PMsamnew says:
i made one in a few hours and it spins SO FREAKING WELL because it is SO LIGHT. i have tried lots of PVC airfoil type blades and they don't start so fast, they're a bit heavy, and sort of scary in that maybe the pvc will crack and explode. these are light and easy and wow.
Mar 25, 2010. 8:44 AMotroandres says:
Is it better to have the generator there? or would it be better to have it with the same axle of the wheel?
Mar 26, 2010. 5:52 AMstormthirst says:
Cons of doing it this way:
You lose a small amount of power to friction
Pros of doing it this way:
Your generator will run MUCH faster. In this rig, for every revolution of the wind wheel, the generator will get 5 revolutions. Faster turning = more power
Oct 6, 2010. 2:48 AMLiquidLightning says:
But less torque.
May 1, 2010. 1:40 AMflying pie says:
thanks i need that  you rock
Apr 28, 2010. 7:32 AMdanial90 says:
I just wanna ask can one use a car generator or alternator for power generation in your turbine
Mar 26, 2010. 6:27 AMkillersquirel11 says:
In this instructable, they made their own generator for the turbine
Pros:  You can spec out the motor exactly the way you need it, more efficient
Cons:  Takes a lot of time.
This article has some different winding configurations if you choose to go that route.
Mar 26, 2010. 6:31 AMkillersquirel11 says:
oh, also, it would be awesome to see someone make one like this DIY.
Jan 30, 2010. 1:55 PMKnexFreek says:
 cool !!!!
Mar 20, 2010. 8:25 PMsontos12 says:
u say "cool !!!" for everything u see! :P
Mar 20, 2010. 8:41 PMKnexFreek says:
 LOL cool!!!
Mar 19, 2010. 12:03 PMmahesh.ganpate says:
how much  blade fixing on  bicycle wheel
Mar 19, 2010. 12:00 PMmahesh.ganpate says:
vaoo..nice  u r brain  can sagess me  generater parameter details
Mar 29, 2009. 5:07 PMmred2 says:
What is the belt made from, and how did you connect it into a continuous loop?
May 14, 2009. 5:08 AMbill3504 says:
its called a lace belt you can remove a link or add links
Jan 11, 2010. 4:35 PMuseful1 says:
Googled lace belt.  I find womens fashion lace belts.  But no lace belts that can be connected made in rubber or sturdy material.
Are you saying the belt is made of cloth?
If I connect a belt using a staple, it adds a bump.  But not a smooth as a solid rubber alternator belt.
Any web links to a "lace belt?"  or a link to a belt that would work?
Jan 24, 2010. 6:50 AMbrymattcrafts says:
You can find "belts" for this at your auto parts shop. They are made to be used for emergency replacements if you lose a drive belt and you can add or remove links to fit any size pulley arrangements
Nov 22, 2009. 2:19 PMRENATO.ROSS says:
se você usasse apenas 3 lâminas ia ficar muito mais fácil o balanceamento. parabéns pelo projeto..........dificuldades da lingua......
Nov 9, 2009. 5:36 PMmelbay49 says:
This is precisely what I'm looking for. How long do you think it would run on a set of bearings? I vaugely remember a line of thought that said windmills housed in airfoils take better advantage of gusts and reduce axial loading. Comments?
Sep 10, 2009. 5:11 AMHycro says:
Ahh...that's how the belting is run...since it uses the rim, it's not absolutely necessary that it has to be a rear wheel...unless you are using the rear wheel because it has a longer axle than the front wheel (though, not by much) and if it's axle length you chose the rear wheel for, a 24"/26" mountain bike rear wheel would be optimal, since it has a longer axle than a cruiser bike (usually no more than 6 speeds, sometimes only one speed with an in-hub brake, known as a coaster brake), or racing bike (those ones with the narrow tires)
Sep 10, 2009. 5:08 AMHycro says:
Wouldn't it work to fold over all but the trailing edges to make the blade stiffer, that way you use less material, the blade is lighter, and is more aerodynamic that two pieces riveted together?? (thinking of rivets and the seam between the two pieces causing drag, or am I just talking nonsense??)
Aug 16, 2009. 3:38 PMcraig0246 says:
where did you get the correct size of belt?
Aug 16, 2009. 3:37 PMcraig0246 says:
this looks very cool! How much power output does this produce? Do you use it to recharge a battery pack or do you have it tied in directly to your power box to your home?
May 24, 2009. 12:24 PMdexknows says:
can you send me schematics
May 24, 2009. 11:12 AMmcflyalright says:
using an oversized cheap rubber rim strip would probably work for the belt on a budget. they stretch a whole lot to so maybe even the rimstrip thats already on it would work. Unless you've got some nice velox tape like the rim in the picture
May 11, 2009. 2:33 PMname0 says:
this is an awesome way to save energy and that is whats important these days:) awesome
Apr 13, 2009. 9:56 PMANDY! says:
You can improve ifficiancy by loosening the bearings on the wheels a bit which was what i did on my bike.
Apr 11, 2009. 7:52 PMghans_00 says:
Sir this is cool, I like it!
Feb 9, 2009. 10:42 AMdrbill says:
This is way cool. I was thinking of using dacron sail cloth at one time but it looks like this is better because only one edge of the blade needs to be connected to a spoke. This even looks like it could be used to power a bench sander or grinder or some such.
Jan 22, 2009. 10:48 AModiekokee says:
I may have missed it, but where can i get info on layout and construction of useful blades? Much oblige,
Jan 22, 2009. 7:28 AMchrisnotap says:
What a great set up. I want to be able to heat my house with a set up some day once I find the right design. Keep up the great work!!
May 12, 2008. 2:39 PMTimAnderson says:
We just built one with a bike chain drive, but that seems to rub the rim and make too much friction. What belt diameter do you like? Pulley diameter? Do you do anything to the wheel to make the belt ride in the middle? Are there any belts/wheels on McMaster.com that would work?
Dec 11, 2008. 2:00 AMcallmeshane says:
IF assuming it's an IF, the rubbing of the chain on the rim is from misaligment, then that's easy fixed. Aside from a direct drive armature / stator, chain drive is about as efficient as it comes - it may not be the absolutely most efficient, what with thin flat kevlar belts etc., but as far as I know it's the most efficient - just below direct gear to gear drive. The BEST method to run indirect drive is via chain, in a DUST sealed GEAR BOX (gears in a box) using a LOW viscosity oil (5W), as a carrier, with a solid lubricant - perhaps some teflon or copper / nickel powder as the actual boundary layer / solid film lubricant. Use contactless labarynth grease / oil seals instead of lipped rubber bearing seals - as the lipped seals create a small amount of drag. Really good efficiencies can be gained through brilliant and quality designs - but who has a team of really trick engineers, wind tunnels and uber clever programmers and super computers on hand; but less than ideal designs can also be radically increased with many small improvements. This is a really good read containing many issues and proven ideas along these lines - not so much the actual drive trains, but the concepts of variations, alterations and the matters of efficiency. NASA/CR-2003-212670 Blended Wing Body Systems Studies: Boundary Layer Ingestion Inlets With Active Flow Control
Jun 22, 2008. 9:15 PMCosantoir says:
Bike chain would seem to make a lot of sense. Rig the rear wheel as a "fixed gear"; someone makes a cheap converter block that replaces the common Shimano freehub body with a solid block, eliminating the freewheel assembly of the freehub. There are spacers available for adjusting chainline, or you can use 1" PVC pipe to make your own. This allows moving the chainline far enough away from the hub that it should eliminate problems with the chain rubbing on the rim. Mounting can then be simplified to just a suitable 10mmx1 bolt replacing the axle. Using a freehub-fixie converter would also make it simple to experiment with different gear ratios in order to tune the generator to the local conditions. On second thought: went looking for the converter: it's called the Surly Fixxer, and they want about $75 for it! Consider Option 2: braze the pawls of the stock freehub mechanism in place, or maybe fill the freehub guts with Liquid Steel or some other sort of epoxy goo? Put the pawls under a slight load while the epoxy sets, to make sure they're engaged. Alternatively, you could use a freewheel rear hub and a track sprocket, held in place by a bottom bracket lock ring. But that's going to cost a fair piece if you have to buy the sprocket new. Once fixed-gear conversions are no longer trendy---which should be any day now---there should be plenty of ex-hipster bikes to be found in dumpsters, at thrift stores, etc. Also worth considering: fabricate a cover for the chain to protect it from the weather and allow oil bath lubrication?
Nov 26, 2008. 12:01 PMfranzwa says:
nice job on the Instructable!!!
1-40 of 100next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:dwarren
I'm a retired (32 years) community college instructor in Digital Media. I'm an aspiring artist in wood and metal.
