Tee Shirt Scarf DIY
Introduction: Tee Shirt Scarf DIY
This is my first Instructable, so please don't patronize me! :-)
Use an old shirt that has no other purpose.
I was going to throw this old shirt away, but I decided to put it to better use!
Step 1: You Will Need...
1 tee shirt (preferably a large or XL)
1 pair of scissors
1 ruler (Optional, not pictured)
Step 2: To Begin...
Start by cutting the hem off the bottom on the tee shirt.
Step 3: Cut It...
Begin cutting the rest of tee up into long strips horizontally along the width of the tee. You can measure your strips anywhere from 1/2in to 1 1/2in for best results. I could not find a ruler so i just decided to wing it;)
Step 4: Finish Cutting...
Cut as many strips as possible from your measurements until you hit the sleeve. I ended up with 9 strands!
Step 5: Stretch It...
Start by stretching all the strands at once. Then grab 4-5 strands and stretch those out. Try to get them to be the same length.
Step 6: More Cut It...
Cut off the sleeve. Then, cut off a strip about 2in thick.
Step 7: Wrap It...
Wrap the strip over the strands as pictured. Then, continue wrapping the 2 strip ends around the strands.
Step 8: Knot It...
Knot the end of the strands together then hide the knot under the folds from the strand.
Ta - Daa!  You have completed your scarf
The End!
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    I ended up making a smaller one out of the sleeve and the rest of the shirt! That minimized the waste! :)
