Teeny tiny rocket engine by killerjackalope
Featured
"Adam you never cease to make me feel like my brain is about to fall out my ears lol you're never just like reading a book"
A text I received after telling Sammi what I did today. This is what I did today.
I am unsure why I did this or what purpose, if any it could serve. It does propel itself in a direction, though it more or less explodes forward it does do it's job, it went straight across, hit the counter, leaving a small mark and then back in to the depths of the kitchen. It may have surprised my housemate a little, probably should have told him why he was lighting my match...
First issue, propellant? I reckon Swan matches, they're pretty bad because they light slower than most. Seems like it's about the right mix of burny but not explodey...
Wait what will I use as the body? More to the point where did this idea even come from if the propellant was the first question? This is some kind of bizarre causation loop in my head.
Anyway I realized an earring back might work, the end of the casing is about the size I'd expect for the nozzle. (I did no science here, I just decided this) I didn't figure out the capping of the other end until later.
Anyway...
Oh stop. This is dangerous, grinding up matches is a logically foolish activity that may lead to burns, break up small amounts at a time to stop it from being a little surprise instead of a burnt hand. Lighting this thing might go badly. Cover your eyes and in general constructing it may be a danger - take care.
Step 1: Tools and Materials
You'll need:
Tools:
 - Pliers
 - A knife
 - A Card
 - A hard surface
Materials
 - Matches (Keep the box handy too)
 - An earring back, clutch back that is, see photos.
Mugsy730 says: Jan 23, 2013. 2:46 AM
Nice work. Anything that goes bang is cool in my book.
Anything that goes bang and flies across the room when your mate is least expecting it is hilariously cool :)
thecrazymagnetman says: Aug 16, 2012. 9:03 AM
I feel sorry for your friend.
killerjackalope (author) says: Aug 16, 2012. 10:48 AM
It's the norm in the house, we're all kind of mad...
thecrazymagnetman says: Aug 17, 2012. 10:52 AM
Why is a raven like a writing desk mad?more?less?
jonrb says: May 8, 2012. 12:33 PM
I used to make small exploding thingies with match powder.
Instead of scraping the dangerous bit off the woody bit, I had an electric pencil sharpener which I wired to a button (Instead of the internal 'pencil detector'). It's a much faster way of stripping the explosive bit off the match, and once you get the knack for it, you have minimal amounts of wood in it.
That said, if anybody tries this and gets burned/injured/killed (Unlikely, as I processed about ~25 boxes of matches with this method.
Good instructable.
killerjackalope (author) says: May 8, 2012. 12:38 PM
Cheers, good idea there...
I know it's unlikely, it's more just well there's always that one person that manages to blow up the house with a paperclip...
Wasagi says: Apr 29, 2012. 6:52 PM
Hahaha, reading this was fantastic. Stream of consciousness combined with fire, good work all around.
killerjackalope (author) says: Apr 30, 2012. 4:45 PM
Thanks, writing falls out of my brain and spills on to the Internet...
dconnolley says: Apr 27, 2012. 11:23 PM
did none of you make match stick rockets as kids? with aluminium foil and a paperclip as the launch pad?
alternative fuels include: model rocket engines, Black Powder, fast burning fuse (comercial grade is difficult for folks to get a hold of but let me assure you an awful lot of fun)
since what your after is a fast burn and not an explosion it helps to compact the dry fuels. enjoy an wear cool safety specs.
Marker1024 says: Apr 27, 2012. 2:38 PM
pliers work really well. just squeeze the tip of your matches and the powder will crumble of in nice clean chunks :).
handyhippie65 says: Apr 26, 2012. 9:14 PM
love your rocket science,"the right mix of burny,but not explodey.." . you definitely want the right balance between those two. too much explodey and they will call you stumpy.
killerjackalope (author) says: Apr 26, 2012. 10:21 PM
Indeed that's why I sciences this so hard...
killerjackalope (author) says: Apr 27, 2012. 12:50 AM
*scienced
medionlvr says: Apr 24, 2012. 8:08 AM
Forget scraping the match head off the stick. up end a bunch of them in enough water to cover. after a day or so all the fuel will come off the stick and you can squeeze it out in a cloth to get a putty. form it any way you want and let it dry. we would use it as an engine propellent by filling a tube with the match putty being sure to add a small tube in the middle, I.E. 3,8" tube with a pen refill. what you end up with is a hollow, packed "sulfur" tube after removing the pen cartridge. the purpose of the pen tube is to allow more surface area to burn. this make a shorter burn but a more forceful drive. it worked for the solid booster rockets on the space shuttle. that's where we got the idea.
killerjackalope (author) says: Apr 24, 2012. 8:20 AM
I thought about doing a hollow up the middle but since I didn't know if it'd work at all I just decided to keep it simple.
I hear acetone can also be used as a solvent for quicker drying.
Thanks for the interesting comment on this - wasn't even sure match powder was worth advancing upon.
medionlvr says: Apr 24, 2012. 6:49 PM
If you will pardon the pun.... It's a blast.
killerjackalope (author) says: Apr 25, 2012. 1:08 PM
Hehe, I'll have to do a bit of experimenting, come up with something cool to do...
tinker234 says: Apr 23, 2012. 7:57 PM
i was looking at making a hand held rocket lancher a elctronic bbg lighter would do to light this or just a barbucaue lighter
killerjackalope (author) says: Apr 24, 2012. 5:45 AM
Sure any lighter could light this but don't know if it'd be any use for that project
Kryptonite says: Apr 24, 2012. 5:16 AM
So, basically an awesome match stick rocket.
Awesome.
killerjackalope (author) says: Apr 24, 2012. 5:43 AM
Yep, pretty much, cheers cap'n
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
