Telephone Handset Microphone
Step 6I lied about the circuitry!
My initial design has no voltage protection (the thing that you were building up until now).
So, realizing that this lack of voltage regulation is a problem, I built the circuit pictured below to kick down the output voltage from 1.5 to 1.2 volts (because rumor had it that this was line level). Line level is still a bit myserious to me, but thanks to a comment posted on the main page by Phatso I can now tell you that line level is probably more around 1v. However, the circuit below should still work fine.
Put together the circuit shown below and shove it inside your case (so that your mic works right and doesn't harm any other devices that you plug it into).
You can also try just using a 100K potentiometer and a 10uF electrolytic capacitor between the telephone jack and the mono jack. This, in theory, will provide volume control and protection from bad voltages. However, I'm not really sure how or even if this will work. This is mere speculation on my part (based on what someone told me once in passing).
Also, a low voltage LED to indicate whether the device is on or off may be nice.
5 comments
Aug 30, 2008. 5:31 PMdoog says:
I, too, would like more explanation of this part.
Aug 31, 2008. 12:35 PMdoog says:
personally, I've never dealt with building circuits before, but I've read up some and have gotten a better understanding of this diagram. But, a picture of your circuit would be helpful.
Feb 8, 2008. 12:52 PMsplatterpaintballer says:
same here. I have no idea
Dec 29, 2006. 12:57 AMdirk gently says:
For me (not-so-experienced), what would this look like? Or How? might be a better question.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1976
Author:randofo(Randy Sarafan loves you!)
I am the author of the book '62 Projects to Make with a Dead Computer' and Community Manager here at Instructables. I'm always sharing tons of awesome projects. Subscribing to me = fun and excitement!
