Temp Sensor DS18B20 (Raspberry Pi)
1,261
32
Posted
Introduction: Temp Sensor DS18B20 (Raspberry Pi)
Basic tutorial of how to setup a DS18b20 temp sensor with the raspberry pi.
Step 1: Parts
Required Parts:
RPI 3 – https://goo.gl/CdVNoH
4 Amp Power Adapter – https://goo.gl/js4Uc7
16GB Micro SD – https://goo.gl/FDqZal
Jumper Cable Assortment – https://goo.gl/7o34sL
ds18b20 sensor – https://goo.gl/8hryFP
Step 2: Setup
1. Edit config.txt
sudo nano /boot/config.txt
add "dtoverlay=w1-gpio" to the bottom of the file
sudo reboot
2. Type the following commands
sudo modprobe w1-gpio
sudo modprobe w1-therm
cd /sys/bus/w1/devices/
ls
3. change directory to sensor instance
cd 28-00000xxxxxxx *serial number is unique
ls
4. check to see if sensor is functional
cat w1_slave
you should see output similar to this
root@raspberrypi:/sys/bus/w1_slave/28-00000495db35# cat w1_slave
a3 01 4b 46 7f ff 0d 10 ce : crc=ce YES
a3 01 4b 46 7f ff 0d 10 ce t=26187
Step 3: Code
Download and run python script:
Step 4: Additional Info
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
