Introduction: Temperature and Light Sensor Data Logger
In this tutorial I make a temperature and light sensor data logger with an Arduino so that I can test different locations for plants or places to sleep outside in the summer that don't get to much sun
Step 1: Things You Will Need
1 Arduino board
1 Breadboard
1 Photoresistor
1 Temperature Sensor
1 SD Card
1 SD Card Reader
1 9v Battery
Jumper Wires
Step 2: Assembly
Hook up the SD card reader:
MOSI - pin 11
MISO - pin 12
CLK - pin 13
CS - pin 4
Gnd - Gnd
5v - 5v
3.3v - NOTHING
Other Gnd - Gnd
Photoresistor:
One end to 5v and the other end to pin2
after the cable to pin 2 there should be a resistor to gnd
Temperature Sensor:
Gnd - Gnd
Vin - 5v (it an also be to 3.3v but you will need to change the code)
Central Pin - Pin3
SD card:
Plug it in (:
Step 3: Code
** MOSI - pin 11 ** MISO - pin 12 ** CLK - pin 13 ** CS - pin 4
#include #include
#define PhotoresistorPin 2 #define TempPin 3 const int chipSelect = 4;
String FileName = "DataLog.txt";
long int LastLog;
void setup() { Serial.begin(9600);
pinMode(TempPin, INPUT); pinMode(PhotoresistorPin, INPUT); pinMode(13, OUTPUT);
Serial.print("Initializing SD card..."); // make sure that the default chip select pin is set to // output, even if you don't use it: pinMode(10, OUTPUT);
// see if the card is present and can be initialized: if (!SD.begin(chipSelect)) { Serial.println("Card failed, or not present");
//turns on the onboard led to signal that something is wrong digitalWrite(13,HIGH); // don't do anything more: return; }
Serial.print("Card initialized.");
void loop() {
//delays 10 minutes while (LastLog + 600000 > millis()) { delay(1000); }
int PhotoResistance = GetPhotoresistence(); float Temparature = GetTemperature(); LogData(PhotoResistance, Temparature); }
void LogData(int Resistance, int Temparature) { //the file you edit File dataFile;
dataFile = SD.open(FileName, FILE_WRITE);
dataFile.print("Minutes Running:"); dataFile.print(millis() / 60000); dataFile.print(" Photoresistor: "); dataFile.print(Resistance); dataFile.print(" Temparature: "); dataFile.print(Temparature); dataFile.println("C"); dataFile.close();
LastLog = millis(); }
float GetTemperature() {
float Temperature = analogRead(TempPin); Temperature = Temperature * 0.48828125; delay(1000); return Temperature; }
int GetPhotoresistence() {
int Photoresistence = analogRead(PhotoresistorPin); return Photoresistence; }
Step 4: Finished!!
Now just plug in the battery and it will start logging data!
