3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Temperature Sensor Tutorial!
What is a temperature sensor?
An analog temperature sensor is pretty easy to explain, it's a chip that tells you what the ambient temperature is!
These sensors use a solid-state technique to determine the temperature. That is to say, they don't use mercury (like old thermometers), bimetallic strips (like in some home thermometers or stoves), nor do they use thermistors (temperature sensitive resistors). Instead, they use the fact as temperature increases, the voltage across a diode increases at a known rate. (Technically, this is actually the voltage drop between the base and emitter - the Vbe - of a transistor. By precisely amplifying the voltage change, it is easy to generate an analog signal that is directly proportional to temperature. There have been some improvements on the technique but, essentially that is how temperature is measured.
Because these sensors have no moving parts, they are precise, never wear out, don't need calibration, work under many environmental conditions, and are consistent between sensors and readings. Moreover they are very inexpensive and quite easy to use.
Some basic stats
These stats are for the temperature in the Adafruit shop, the Analog Devices TMP36 (-40 to 150C). Its very similar to the LM35/TMP35 (Celsius output) and LM34/TMP34 (Fahrenheit output). The reason we went with the '36 instead of the '35 or '34 is that this sensor has a very wide range and doesn't require a negative voltage to read sub-zero temperatures. Otherwise, the functionality is basically the same.
  • Size: TO-92 package (about 0.2" x 0.2" x 0.2") with three leads
  • Price: $2.00 at the Adafruit shop
  • Temperature range: -40 degrees C to 150 degrees C / -40 degrees F to 302 degrees F
  • Output range: 0.1V (-40 degrees C) to 2.0V (150 degrees C) but accuracy decreases after 125 degrees C
  • Power supply: 2.7V to 5.5V only, 0.05 mA current draw
  • Datasheet
Step 1How to use a temperature sensor
How to measure temperature!
Using the TMP36 is easy, simply connect the left pin to power (2.7-5.5V) and the right pin to ground. Then the middle pin will have an analog voltage that is directly proportional (linear) to the temperature. The analog voltage is independent of the power supply.
To convert the voltage to temperature, simply use the basic formula:
Temp in Celsius = [(Vout in mV) - 500] / 10
So for example, if the voltage out is 1V that means that the temperature is ((1000 mV - 500) / 10) = 50 degrees Celsius
If you're using a LM35 or similar, use line 'a' in the image above and the formula: Temp in Celsius = (Vout in mV) / 10
Testing your temperature sensor
Testing these sensors is pretty easy but you'll need a battery pack or power supply.
Connect a 2.7-5.5V power supply (2-4 AA batteries work fantastic) so that ground is connected to pin 3 (right pin), and power is connected to pin 1 (left pin)
Then connect your multimeter in DC voltage mode to ground and the remaining pin 2 (middle). If you've got a TMP36 and its about room temperature (25 degrees C), the voltage should be about 0.75V. Note that if you're using a LM35, the voltage will be 0.25V
(See image below)
You can change the voltage range by pressing the plastic case of the sensor with your fingers, you will see the temperature/voltage rise.
(See image below)
Or you can touch the sensor with an ice cube, preferably in a plastic bag so it doesn't get water on your circuit, and see the temperature/voltage drop.
(See image below)
Connecting to your temperature sensor
These sensors have little chips in them and while they're not that delicate, they do need to be handled properly. Be careful of static electricity when handling them and make sure the power supply is connected up correctly and is between 2.7 and 5.5V DC - so don't try to use a 9V battery!
breadboarded to-92 -
They come in a "TO-92" package which means the chip is housed in a plastic semi-cylinder with three legs. The legs can be bent easily to allow the sensor to be plugged into a breadboard. You can also solder to the pins to connect long wires. If you need to waterproof the sensor, you can see the next step for an Instructable for how to make an excellent case.
28 comments
Jun 1, 2011. 1:03 AMTerryKing says:
I would think about going to the Digital sensor DS18B20. A how-To for Arduino is here: http://arduino-info.wikispaces.com/Brick-Temperature-DS18B20
Jan 5, 2011. 7:28 AMmattadamsnet says:
174
6.18V power supply
0.84 volts
33.88 degress C
92.98 degress F
173
6.22V power supply
0.84 volts
33.76 degress C
92.76 degress F
Heres the problem, .. its more like 70-72 degrees in here and im using USB power which my volt meter measures at 5.10v, the sensor @ the sensor is measuring .583v help me out here.
Oct 11, 2010. 9:06 PMmbainrot says:
From memory there is a way to change vref so you can do the 3.3v scale on a 5v arduino.
Be careful as from memory you can damage the 'druino if you feed it 5v when the ADC is expecting 3.3v
Jul 29, 2010. 6:38 AMdgallimore says:
This is great! I've never found such a simple explanation as to how to use an Arduino before. Could you tell me though, what's the maximum length that the wires can be between the Arduino and sensor? Thank you for a great 'ible!
Jun 9, 2010. 4:28 AMjohnnyhellfire says:
This was a great idea and has taught me a lot about this platform. had a suggestion thought, how bout if you can find a way to put the read out on a pc and a built in lcd screen, that way you can take this anywhere and it ll let ya tell you the temp where ever you are. the applications in ghost hunting would be tremendous.
Jun 16, 2009. 4:28 AMPlasmana says:
Wow, they are so much you can do with the Arduino, I must get my self one...
Jun 17, 2009. 9:59 AMReCreate says:
Yeah, I may get myself one...
Jun 17, 2009. 3:16 PMPlasmana says:
Thats cool
Jun 17, 2009. 3:35 PMReCreate says:
Yeah
Jun 18, 2009. 10:13 AMPlasmana says:
lol
Jun 18, 2009. 10:15 AMReCreate says:
Laugh out loud...
Jun 19, 2009. 7:42 AMPlasmana says:
Meh, 'lol' is easier to type. :-)
Jun 25, 2009. 7:22 PMReCreate says:
I'm getting myself an arduino(and now that i am typing it more often i now know how to spell it right! :P), The lowest price i found anywhere on the internet(blagonet, blagoshpere lol what did i say lol? lol) at $27.9869 American dollars! But it is the Older one, From 07 the latest one from 09 is the one i want for like 3 dollars more at 29.99 American Dollars. On ebay i found one for 19.99, but of course, its a fake, coming from hong kong and having more than 10000 of them...so yeah...
Jul 11, 2009. 3:50 PMandros1200 says:
Get the Duemilanove. It's worth the extra $3. >.> It automatically switches to the power source your using, so you don't have that annoying jumper, and with the ATMega328p it has twice as much storage space for sketches and twice as much ram and EEProm compared to the Diecimillia.
Heres a good place to get one:
http://www.sparkfun.com/commerce/product_info.php?products_id=666
If you havn't already gotten one.
Jul 11, 2009. 7:19 PMReCreate says:
I'm getting a duemilanove from some place for about 27 dollars, look for my topic about it
Jul 12, 2009. 3:57 PMandros1200 says:
Just be sure to build a robot that takes over the world and it has to look like this:
http://bbs.chinadaily.com.cn/attachments/month_0805/cute%20little%20bunny_LZcNR0iKF5qw.jpg
Jul 12, 2009. 5:12 PMReCreate says:
lol, I would need an arduino nano XD
Jun 19, 2009. 11:25 AMReCreate says:
GRRR
Jul 2, 2009. 12:41 PMllanyort says:
how many seconds do i need to wait between polling the sensor ? i would like to poll the sensor every .5 - 1 second. is this feasible ?
Jun 18, 2009. 5:59 AMPaloAltoMark says:
Artificial Intelligence: Thanks for your help. The link you provided to the wiki was very helpful. It seems that type K thermocouples are the most practical for hobbyist use. For those interested, you can purchase a type K for $6 at the below link: http://www.virtualvillage.com/thermocouple-with-14-x-4-type-k-probe/sku003820-031. I'm sure there are plenty of other sources as well; (If your oven came with a meat probe, you have a thermocouple)
Jun 17, 2009. 6:03 AMPaloAltoMark says:
Is anyone aware of similar temperature switches that would work at high temperatures such as those in a BBQ grill (200-600 degrees F)?
Jun 17, 2009. 6:19 PMkikiclint says:
I know they make thermistors and thermocouples which would work in that range.
Jun 18, 2009. 5:46 AMPaloAltoMark says:
Thanks much for the help
Jun 17, 2009. 11:30 AMArtificial Intelligence says:
For measuring such high temperatures, you may want an other type of temperature sensor called a thermocouple.
Jun 17, 2009. 3:41 PMReCreate says:
It's shaped like a transistor?
Jun 16, 2009. 10:20 AMSwishercutter says:
Great Instructable. $2 seemed high for the TMP 36...I found them on Digikey for a bit less, $1.35 http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=TMP36GT9Z-ND Prices drop as you go higher in quantity.
Jun 16, 2009. 8:04 AMjj37 says:
Great instructable 4 stars and thanks I always had a bit of difficulty with accuracy.
Jun 15, 2009. 10:55 PMReCreate says:
I never knew about these before! Very interesting!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
234
Author:adafruit(Adafruit Industries)
All-original DIY electronics kits - Adafruit Industries is a New York City based company that sells kits and parts for original, open source hardware electronics projects featured on www.adafruit.com ...
more »
