Temporary Tattoos :)
13,150
58
5
Posted
Introduction: Temporary Tattoos :)
Step 1: What You Need
•ink pen. I used a fineliner and it works well, a gel pen could work just be careful not to put on too much ink.
•paper. Tracing paper or greaseproof paper is best to use but i didnt have any left so i used normal paper here and it worked ok although it did run a bit.
•cloth and warm water
Step 2: Draw Your Designs
You can design them in pencil first if you want then go over them in pen but i just drew them straightaway in pen i think its easier. Colour over thickly but try not to have liquid ink on it.
Step 3: Text
Remember that it will be flipped around when you put it on your skin. If you want to do a design with writing on an your not very good at mirror writing then draw it on in pencil and trace it on the other side in pen.
Step 4: Cut Out Your Design
Cut out the one you want to use and decide where to put it. I would recommend doing a small ish one for the first attempt and put it somewhere you can easily reach like your arm.
Step 5: Print It
Put the design side of the tattoo towards your skin. Use an cloth with warm water but wrung out and put it on the paper for about 30 seconds. Then peel it off and leave it to dry in the air.
*you need to actually put the cloth on the paper and hold it on but i needed my other hand to take the picture.
Step 6: Done :)
It should last a few days. If you want it to last longer you can put hairspray on it as well. Mine ran a bit but like i said i think its because of the paper because i have done this method before and it worked fine.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
5 Comments
Does this work with sharpies? I can't find any liquid ink pens anywhere but online and I have a ton of sharpies
does this work with any pen and on printer paper?
It needs to be an inky pen, for example a biro wouldnt work, gel pens should be ok just make sure its completely dry i havent tried it before it might smudge. I think a fineliner is best. I would normally use greaseproof baking paper for this because it transfers the design better but i used printer paper in the picture and as you can see it works just isnt as clear.
Yh the moon 1 at the top i wht im doin on my arm at the carnival and a cresent moon outline on the tiny bone by my neck
I was trying to find out the other day how 2 do this
