Step 5Fit the turnbuckles and tighten
Repeat for each of the four bottles. Tighten the turnbuckles as much as you can by hand. This should easily be sufficient for rigidity and tools should not be required.
The turnbuckles are designed to sit at an incline in order to increase the torsional strength of the table. This resulted from testing an initial prototype, in which case the turnbuckles gradually loosened over time as the table was used as a footrest or otherwise pushed around from the side. So hopefully that should be fixed here.
Add Comment
