Ten minute bazooka
What you need: 3/4" pvc pipe, pvc cap to fit the pipe, rubber mallet, Co2 cartridge (the kind for soda siphons), screwdriver, drill, drill bits, Dremel
Step 1: Step 1
Ten minute bazooka
microman171 says: Nov 5, 2010. 3:26 PM
How exactly do you use the Bazooka?
apple is cool still (author) in reply to microman171Nov 6, 2010. 1:11 PM
Slide the CO2 in the pipe and than tip the pipe so that the CO2 is in the front then
ram the pipe
if this does not make sense watch the video on step 6
ElusiveGreen in reply to microman171Nov 6, 2010. 9:00 AM
Just looking at the design, I'd say that it functions more like a mortar. You have the pipe sitting on the ground, with a vertical angle. Then you drop the CO2 cartridge in, it slides down, pieces on the screw and launches itself back out. Sounds like it would be incredibly difficult to aim and rather unsafe. I just don't see what the inner tube is for, insulation from the cold?
apple is cool still (author) in reply to ElusiveGreenNov 6, 2010. 12:45 PM
TyrenRaven it is not for insulation  it easier to hold because it slips
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
