Tennis Ball Holders
Introduction: Tennis Ball Holders
Step 1: Tennis Ball Holder
This is an idea I had got online hope you enjoy
Step 2: Parts
3 tennis balls
A ping ping bat
Marker pen
Hot glue gun with glue stick
Step 3: Cut
Cut a slit in all three balls
1. Make a small slit in the ball using a knife
2. Use the blade to make the slit bigger
Step 4: Design Your Tennis Ball
Using the marker pen I made lips around the slit
You can do your own design as you wish
Step 5: Glue It
Using a hot glue gun spread the glue at the back of the tennis ball and stick it onto your ping pong bat.
I did it on three corners, you can do it as you wish.
Step 6: Test
The ping pong bat had a hole at the handle side in which I used to hang and test it.
Step 7: Decorate
I decorated it with newspaper clippings. I glued it with wood glue to the ping pong bat and set it aside to dry for at least an hour
Step 8: How to Use It
Squeeze the side of the ball so that the slit opens and put what you want for it to munch on and pull it out when you need to get it. Hence the final product
Hope this will help others out there
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Epilog Challenge 9
      Epilog Challenge 9
    I love the added lipstick design!
