3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tennis Shoe Repair: Torn Heel Linings
If you take tennis shoes to most shoe repair places with even the most basic problem, they'll tell you that they're not fixable; you should throw them away and buy some new ones. For some shoes, that's still the best policy, but it's not the only option. Higher-quality shoes are often repairable with a little time and extra effort.
In this Instructable, I'll be sharing with you the repairs I did to bring my Patagonia Huckleberry shoes back up to snuff. The heel lining was worn through in one of the shoes, so I'll walk you through replacing the other lining.
These repairs took a couple of scraps of cloth, a little bit of thread, and couple of hours of work.
Step 1Remove the Old Lining
The lining is attached with a single straight-line stitch in this pair of shoes. It is sewn onto the shoe inside out and flipped over the edge of the shoe for a hidden seam. Seams in contact with feet equals possible callouses and blisters.
Use a seam ripper or razor blade to tear out the old seam and remove the lining fabric. It will likely be attached with some sort of spray adhesive to several layers of foam. You will need to pry up the sub-footbed of the shoe (correct term?) and pull the tail of the fabric from the bottom of the shoe.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:freewheel
I'm a compulsively curious guy. I have taken things apart all my life, intrigued by how things work. I didn't know other tinkerers growing up, so I've learned mostly by doing or through the internet. ...
more »
