Tension Set Pearl Pendant
 by Mrballeng
Contest WinnerFeatured
Step 5: Set the tension
To get the right tension on the pearl I started by forming the metal strip into a letter “U”. This was done with a pair of vise grips and the ¼” metal dowel of a grinding bit. From there I pinched the “U” shut over the dowel. See the pictures.
When I’d let go of the setting it would spring open just a little. To remedy this I held the setting closed and heated it until it was red hot. Next I quenched it in water. Now when I let go of the setting it stayed closed. This means the setting will want to spring closed instead of wanting to spring open.
The last two pictures are before and after heating.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
