iImage Information
I have constructed some Popsicle stick pocket crossbows out of some things lying around at home. I am contemplating a step-by-step instructable for everyone, however I'm worried some kid will make one and decide it was a good idea to shoot his sibling in the eye at home. These are extremely powerful for their size. (even a blunt ended bolt [basically the flat end of a nail] ripped the skin off of my leg and made me bleed.) with that being said, I am in no way responsible for what you do if you decide to try and re-create what I have here.
I used popsicle sticks and pieces of paper clips as the triggering mechanism, around a 4 inch piece of steel rake for the bow, and jewelers wire/crimps for the draw string.
This is my first Instructable, if enough of you like it, I'll post how I made it in the coming weeks or so.
Thanks for viewing. :).
However, if anyone is curious if string works.. It works pretty well. I used outdoor string specifically used for coats and made it much like real crossbow strings are made, but the force needed to pull it back, it broke a few days later. (probably because I put super glue on it) I decided on wire because it's much easier, and less time consuming to replace.
Just curious.. didn't you made a crossbow just like this ones but all in small steel parts?? with 2 type of projectiles a piercing metal arrow and a blunt metal "arrow" ??
because i saw a video about it some months ago and the concept looks exactly the same
regards Taimur
Isn't the concept of every crossbow the same? A bow fixed crosswise on a wooden stock (not always wooden, we'll just say a stock) with grooves in the stock to guide the projectile.
Anyway You made a great job and I will be making one with the same principle, my only problem was thinking about the bow material I never thought I would have a good material that would bring enough tension to the wire.
about You doing such an instructable of it... I dont advise, You give already enough information to make one. There are a lot of information out there about doing an crossbow and this one is quite powerful for is size.
It is quite dangerous depending on the thickness of the bow..
I do concur with you, though. I don't believe these are very safe if a child gets a hold of one. I'm currently working on a smaller version of these that shoot toothpicks, these smash the toothpicks to bits once they reach the wall. I have a prototype, and it works very well, I just haven't gotten around to posting it on here yet.
To those of you who do end up reading this, the toothpick shooting crossbow stores in a case roughly the size of a tube of chap stick. The only pocket crossbow that safely fits in your pocket without breaking, or poking you with anything. However, it does pierce skin. (I shot myself in the finger trying to shoot an apple, it went in about 1/8th of an inch) With that said, I won't be posting a how-to instructable. Just pictures of it. But on the bright side, it has the same trigger mechanism as these do. Just a different bow, and a rig to hold 3 bolts on one side, and a bow on the other side for storing it in your pocket. I'll have it posted in a few days.
thanks,
~cobalt420
