Introduction: Tertial Webcam
The Tertial light offered by IKEA has the potential to be much more than just a work lamp. Its adjustable arm and many points of articulation make in an excellent platform for mounting things. In this Instructable, I'll show you how easy it is to combine the Tertial swing arm with a webcam to make an articulated camera.
Step 1: Supplies & Materials
Required materials:
- Tertial Lamp
- Sugru, or all purpose adhesive
- needle nose pliers
- philips screwdriver
- rubber bands (to stabilize the cam while the adhesive dries)
- a few zip-ties for cable routing (optional)
[If you don't already have a Tertial you can get one at your local IKEA for around $9.00]
Step 2: Preparing the Tertial Arm
- Start by removing the shade from your Tertial.
- Remove the two screws holding the switch and socket assembly the arm.
- Take a moment to make sure your lamp is NOT plugged in.
- Now cut the cord, freeing the socket and housing.
- The lamp cord can now be removed, perhaps for use in another project, or just to get it out of your way.
- The springs can also be removed now. Unless your webcam is extremely heavy, they won't necessary.
Step 3: Choose Your Cam
Step 4: Prepare the Webcam for Mounting
Now is a good time to look for a mounting point on the back of your webcam. The C200 has a nice void just below the data cable exit point.
Step 5: Choose Your Glue
Step 6:
I applied two grams of Sugru to the end of the arm and pressed it into the back of the web-cam.
I used rubber bands to hold the cam in place, and then proceeded to use the rest of the Sugru covering things up and filling a small hole I made when removing the clip mount.
Allow 24 hours for Sugru to cure, or wait the specified amount of time for your adhesive of choice.
