3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Test Network and Internet Latency (Windows only)
First of all latency is aka. lag. This instructable will teach you how to check your connectivity to the network for windows. You will need the command prompt, aka. CMD, for this instructable.
Disclaimer: I found this on WikiHow and thought I should share this with the Instructables community!
Step 1The Command Prompt
The Command Prompt
In this step I will teach you how to get the the command prompt.
Method 1: (Pictures)
1. Press Start
2. Press Run
3. Type in Cmd
4. Press Ok
Method 2:
1. Press Start
2. Press All Programs
3. Press Accessories
4. Select Command Prompt
Start > (All) Programs > Accessories > Command Prompt
Method 3: Vista / 7
1. Press Start
2. Type Cmd
4. Enter
4 comments
May 26, 2010. 11:11 AMmatrix828 says:
great 'ible, but on mine the average time was 39-40 ms lol...rubbish broadbrand, good network card LOL
Sep 2, 2009. 6:34 AMmr.incredible says:
Every little tool helps... Ping doesn't really tell you anything other than you have a connection to the device you are pinging and the TTL (Time To Live) Basically the time it takes to get a response. You can see if there are problems somewhere on your network, but there are a lot of devices between you and the public site you are pinging. A better tool to use would be tracert (Windows) traceroute (Linux). (See attached) Even that will not show much of your local network. It basically will show the time between each hop or router you hit. You only need to replace network cards and cables if there are serious delays on the first hop. Even then you could be chasing wild geese. Other things on your home or work network could be causing packet storms. A looped back cable on your router or switch will cause slow connections or even stop the network. If you are wireless, signal strength is the biggest factor. Other things like badly configured DHCP or manual settings on your network connection can cause slowdowns too. The wrong or a slow responding DNS server will cause serious lag with the first hop.
Aug 31, 2009. 1:58 PMclempar55 says:
It is not "Windows only" since the ping command (and of course the command line interface) also exits on other OS like Linux ( and certainly Mac OS, but I didn't test)
Aug 31, 2009. 1:11 PMlemonie says:
Well done for not just copying the whole thing (it has happened) - but you've stopped short of saying anything about what this does or what the results mean. Can you fill that gap? L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:mrmoneybagss
I am a guy who lives in California. During my spare time, I like to see if somebody posts a decent instructable that I would like to try. I also love to play xbox 360.
