Test your radar detector or laser jammer with this traffic enforcement LIDAR gun simulator
This LIDAR gun simulator mimics eleven different traffic enforcement LIDAR guns.  Each Lidar
gun operates at 904nM wavelength with short pulse bursts, some guns operate 100 pulses per second, some guns at 238 pulses per second, etc.  The Laser Atlanta LIDAR guns offers a special stealth mode" to defeat early laser jammers by hiding some of the pulses and confusing their detection circuit.  This simulator can reproduce the "stealth mode" to see if your equipment
is vulnerable.  Only radar detectors that detect LIDAR threats are useful for testing, as this
only transmits light not radar.
The following is a list of LIDAR guns it can simulate:
Jenoptik Laveg
Jenoptik LaserPatrol
Kustom Prolaser 1
Kustom Prolaser 2
Kustom Prolaser 3
Kustom ProLite
Laser Atlanta
Stalker LZ-1
Ultralyte 100/200 LR Revision 1
Ultralyte 100/200 LR Revision 2
Ultralyte Non-LR
Parts required:
16x2 LCD (HD44780 compatible)
(purchased on ebay for $7.50)  It helps to search as 1602 LCD.
940nM LED (close enough to 904nM) 1.5V voltage, 60mA continous
(purchased on ebay for $2.99 for ten)
Arduino board with 3.3V power available
(purchased on ebay for $21.59 Duino 328)
90 ohm resistor (or larger)
10K ohm resistor
10K ohm potentiometer
pushbutton
wires
Step 1Schematics, LCD
Schematics, LCD
The schematics are broken into four segments.  I suggest wiring the LCD first and make sure that works before continuing on, as this makes troubleshooting much easier.
5 comments
Nov 17, 2009. 4:28 AMStephen D. Alverez says:
 First comment! pretty good. But there is no way to make a LIDAR jammer.
I
V
O
T
E
D
Nov 25, 2009. 8:09 AMG-Zona says:
(removed by author or community request)
Nov 29, 2009. 1:58 PMStephen D. Alverez says:
But if you notice he aims right at the light on the car, which will mess it up if you aim at it, but you are not supposed to aim like that!
Nov 30, 2009. 5:55 AMG-Zona says:
I see that you don't know about how LIDAR operates. It will reflect of any reflectable surface, especially license plates and headlights. That is why there is a substance called VEIL, so it decreases LIDAR reflection of all glossy surfaces.
The police officer will aim to your headlight when you don't have front LP, cause it's the most reflective surface.
There are more videos on youtube, or you may google using laser jammer video as keyword.
Nov 22, 2009. 11:35 PMgentry says:
This is indeed pretty cool.  The giant switch statement is ripe for factoring, though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:BlackLight99
