3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Test Tools: A polarity tester
This is a simple but very handy little device to have around the home and workshop, which will help determine the polarity of two wires, or contact points of a DC circuit.
EDIT / UPDATE: If you wish to also use this circuit for voltages LOWER then 12 v or so, you may need to install a bypass switch over the resistor and to be safe, include a 1 k resistor in series with the switch.
Step 1Gathering the parts
Gathering the parts
There aren't many parts to this. I didn't even use a pc board, although you certainly may. A small strip of one just a 4 -6 hole wide is sufficient.
R1 = 11 K 1/4 W resistor
D1 = 1 Bright Green LED
D2 = 1 Bright Red LED
D4, D5, D6, D7 = 4 1N4004 (or you can substitute 1N4005, 1N4007) Silicon Rectifier Diodes.
Misc: PC Board (optional), wire, case, Probes / Clips
Tools: soldering iron, needle nosed pliers, possibly hot glue and glue gun, etc.
23 comments
Jul 26, 2009. 1:09 AMknexsuperbuilderfreak says:
ah i rember whem i had a eletronic kit and i exploaded a led because i put it i wrong and this will prevent that great job
Jul 15, 2009. 7:43 PMthermoelectric says:
Is there a need for the diodes? Since the LED's are diodes, I wouldn't think the extra ones are needed..
Jul 15, 2009. 8:11 PMthermoelectric says:
Wow! I'm really suprised you could apply it directly to 110VAC without burning the LED's. Test it on 220VAC :-P
Jul 16, 2009. 12:16 AMthermoelectric says:
Cool
Apr 13, 2009. 1:32 PMdrbill says:
HAY ! Yours got more parts than mine. What's the deal ? I especially like the goop you used to cover it all. All in all I think yours is a better circuit. I like it ! Mine is only good for around 12v. or less. I like yours. I think I'm gonna use a rotary switch to change out the diodes though. Excellent work ! Thank You. DrBill KB1LZL 73's
Jan 24, 2009. 7:00 AMKiteman says:
I have just acquired a bunch of LEDs that will light up red or green, depending on the direction of the current through them.
Apr 13, 2009. 1:33 PMdrbill says:
The negitive leg.
Jan 24, 2009. 10:05 AMKiteman says:
I did, but I'm sure others didn't.
Jan 28, 2009. 10:32 PMnavarrofeds says:
thanks great job this is really useful
Jan 29, 2009. 11:43 PMnavarrofeds says:
thank you again I am going to try and gather some stuff this weekend to make one
Jan 24, 2009. 8:15 AMGjdj3 says:
That's cool! I agree with Nacho, it may not look great but it sure looks useful!
Jan 23, 2009. 7:20 PMPhil B says:
In step 1 did your really mean to designate D1 and D2 as resistors? Did you mean LEDs or diodes? It is a neat circuit, and simple.
Jan 23, 2009. 5:32 PMNachoMahma says:
. Great job.
. I don't think it will win any beauty contests, but it's still a great job. heehee
. Will it really work at 15VDC and 115VAC? That's quite a range.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
138
Author:Goodhart(Old as the hills...)
I am, most definitely older than 00010101 and to put it simply, still curious about nearly everything :-) I then tend to read and/or experiment in those areas - when I have the time... My two "spe...
more »
