3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Test Tools: Plant Soil Moisture Monitor
I am going to start with a simple moisture meter one can carry about and test all their plant soils with, rather have one committed to one plant and needing one for each plant, as I had originally planned.
Insert the probe into the soil, push the button and it gives a go / no go signal whether the soil is damp enough or not.
Step 1Parts
Parts
PARTS LIST:
IC1: 4001 CMOS 2 input quad NOR gate (14 pins)
D1: Red LED
D2: Green LED
R1: 22 K resistor
R2, R3: 200 ohm resistor
R4: 100 ohm resistor
R5: 200 K trimmer resistor
One 14 pin IC socket
Misc: copper or copper clad probe, 9v battery connector, 6 lengths of insulated wire, and a pc board, box (I used an empty SwingLine staple box).
NOTE: IF you use a section of copper for the probe rather then a copper CLAD board, you will need 2 of them, and a bit of insulation attached in between the two pieces.
14 comments
Jan 26, 2009. 5:45 PMNachoMahma says:
. Good job. And prettier than the polarity tester. ;)
Jan 26, 2009. 6:13 PMNachoMahma says:
. We seem to have the same opinion of tools: As long as it works, who cares what it looks like. :)
Jan 27, 2009. 1:04 AMNachoMahma says:
> requires adjusting, depending on the type of plant ... Do you think I should explain that it more detail?
. Since this is in Home, then yes. You don't need a lot of detail. A few links to pages that will help the user determine the proper moisture. Point out that repeatable insertion depth is important. Will need to be re-calibrated as probe corrodes.
Jan 26, 2009. 1:19 PMGjdj3 says:
Sweet! Another project from Goodhart! This is great because I'm trying to grow a baby pine tree right now.
Jan 26, 2009. 5:06 AMgmoon says:
That's cool. You've been a busy maker lately ;-).
Jan 26, 2009. 10:22 AMgmoon says:
That's the best kind of sickness--nobody wants to be around you, but you feel well enough to "play..."
Jan 26, 2009. 12:28 AMgmjhowe says:
Excellent work! i did not realise it was going to come out so soon. And.. Nice Box!! see how much a difference a box can make??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
138
Author:Goodhart(Old as the hills...)
I am, most definitely older than 00010101 and to put it simply, still curious about nearly everything :-) I then tend to read and/or experiment in those areas - when I have the time... My two "spe...
more »
