- through a wire in your weapon (except sabre)
- up your sleeve and down your back through your bodycord
- through a long cable that connects you to the reel
- across the floor in a floor cable
- into the scoring machine
Tools Needed: screwdriver, small screwdriver (5/64), pliers, wire cutters, wire stripper (or a knife), something to test resistance (e.g., volt-ohm meter, continuity tester, or specialized fencing tester such as the Leon Paul TT10)
Remove these ads by
Signing UpStep 1Initial Testing
The wires in the bodycord all go straight through. When we take measurements we will be testing the Outside Pin on one end of the cord with the Outside Pin on the other end of the cord. Similarly, we'll test the two Middle's and the two Insides. When we test them, we want to make sure we have low resistance, or at a minimum continuity.
For example, when I tested the bodycord below I got:
- Outside-Outside = 0L (no connectivity)
- Middle-Middle = 0L (no connectivity)
- Inside-Inside = 0.4 Ohms (connected. OK)
PS:GO EPEE WOOT!!!!!!!!!!!
Does any one know if it's possible to buy some kind of wire (for instance, from HomeDepot) for replacement?
Thanks.
"In the sport of modern Olympic style fencing,"
For us historical fencers that is just a little more accurate :)
