Tetrahedron LED Light
905
7
Posted in TechnologyLeds
Introduction: Tetrahedron LED Light
I am always interested in the idea of "module". It provides freedom to create a unique piece of each user.
This intractable will teach you how to make a pressure sensitive module tetrahedron light.
The materials you need is as blow.
Material:
Wires
single color LEDs
Attiny 45 or Attiny 85
Arduino board
Piezo element
Copper tape
3V cell battery
Battery holder
Other materials:
Foldable translucent plastics
Masking tape
Magnetics
Hot glue gun
Step 1: Fold the Tetrahedron
Cut the plastics into the shape as the picture. The width of the triangle is 3.5 inch. You can adjust the size, but make sure it's not too small to fit all the circuit in.The plastics may be a little bit hard to work with. Make sure you use a folding bone to score it before you start folding.
Step 2: Build the Circuit
Now let's start to make the circuit.
If you are not familiar with working with a Attiny, please see this link. http://highlowtech.org/?p=1695
It will teach you how to use your arduino board to program the attiny.
The code that need to upload to Attiny is as below:
// these constants won't change:
const int ledPin = 0; // led connected to digital pin 0 const int knockSensor = 3; // the piezo is connected to analog pin 3 const int threshold = 60; // threshold value to decide when the detected sound is a knock or not
// these variables will change: int sensorReading = 0; // variable to store the value read from the sensor pin int ledState = LOW; // variable used to store the last LED status, to toggle the light
void setup() { pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT // Serial.begin(9600); // use the serial port }
void loop() { // read the sensor and store it in the variable sensorReading: int sensorReading = analogRead(knockSensor); // if the sensor reading is greater than the threshold: if (sensorReading >threshold) { // toggle the status of the ledPin: ledState = !ledState; // update the LED pin itself: digitalWrite(ledPin,ledState); // send the string "Knock!" back to the computer, followed by newline // Serial.println("Knock!"); } delay(100); // delay to avoid overloading the serial port buffer }
Step 3: Assemble the Tetrahedron
Put the circuit inside the tetrahedron. Make sure the circuit is working before you put it in.
Tape the piezo and the magnetics together on one of the side of the tetrahedron. And put three other magnetics on the other three sides as well. Watch the positive and negative side of the magnetic and make sure they attract when two tetrahedrons are put together.
Step 4: Finish and Play!
Make as many pieces as you want! Now you can start to play with your module lights and assemble them in different ways as creatively as possible.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
