3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
START VOTING!
We have 32 prizes, so please vote for more than one winner!
IS THIS A WINNER?
Tetris Bookshelf
Tetris Bookshelf
In honor of the longstanding tetris rivalry between members of the instructables staff, I designed a set of tetris bookshelves for the instructables office using Autodesk AutoCAD and new preview version of Autodesk 123D Make.  These shelves are great because they can be rearranged and stacked anyway you like, and you can always make more if you need them.  I used a laser cutter to cut the shapes out, making the whole process quick and minimally labor intensive.
Step 1Modeling in AutoCAD
Modeling in AutoCAD
The tetris shapes are fairly straightforward; each piece is made of four unit pieces arranged in seven different orientations.  Since I chose to make my shelves without a back panel, the S and L shaped pieces can be flipped over to produce their mirror images.  This means that I only needed to make 5 types of pieces.
I modeled the shelves in AutoCAD by drawing the shapes in 2D, extruding them into 3D and subtracting the inner volumes.  The final shelves will be made from 3/4" plywood, with each unit piece measuring 9" inner diameter and 10.5" outer diameter.  The depth of the shelves will be 15".  For now I've only built a prototype set which has been scaled down by 1/3 and cut from 1/4" plywood.  I exported these shapes from AutoCAD as a single stl file to send to 123D Make.
I've attached the dwg and stl files for both the full sized and scaled versions of my tetris shelves.
13 comments
Feb 27, 2012. 3:23 PMamason9 says:
Want. Definitely adding to my long list of build projects.
Feb 23, 2012. 6:48 PMjwarning says:
Nice! How are you going to cut the joints on the big ones?
Feb 23, 2012. 1:26 PMRartemass says:
Just a question, how stable and strong is this design in practice? I love the concept but some of the pieces look like they may sag under the weight of books and more robots. Maybe applying some backing material to ensure the pieces retain their shape would help?
Feb 21, 2012. 4:17 AMJohnsonJ says:
Great Stuff!
Feb 19, 2012. 6:49 PMOutlawKtulu says:
I have access to a laser cutter but not autocad. Any idea if these files can be imported into Inkscape?
Feb 20, 2012. 10:05 PMJayefuu says:
No, but GIMP will open the EPS file that Amanda included in step 2. From there you can save it as a DXF for use in Inkscape.
Feb 20, 2012. 11:09 AMLindie says:
Awesome! And I love your robot!
Feb 19, 2012. 11:30 AMamwaymart says:
Rly Amazing!!!
Feb 19, 2012. 9:48 AMjacobkoski says:
How long did the assembly/glue up process take?
Feb 17, 2012. 4:04 AMresidentevil5 says:
this is amazing yet simple.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:amandaghassaei(amandaghassaei.com)
Currently working for instructables!
