3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tetris Ice Cubes
Tetris Ice Cubes
  • last photo ←
Make your own tetris block silicone ice cube tray.
The mold created in this project can be used for much more than just ice cubes- try making Jello tetris pieces, or tetris soap, tetris Popsicles, or even tetris ground beef squares!
Mmmmm ... ground beef squares
Step 1Materials
Materials
The materials and design for this project are somewhat flexible. The idea is to create many different 1" cubes, and piece them together in the form of the tetris pieces. The tetris pieces are then assembled on a board, creating a positive for liquid silicone to be poured on.
1. 1" thick wood (or any other solid material you have the ability to make the cubes out of; ie acrylic or metal can also be used)
2. Saw
3. Ruler
4. Sander
5. Wood glue
6. Molding Silicone
7. Hot glue gun
8. Exacto knife
240 comments
1-40 of 240next »
Jan 22, 2012. 3:49 PMHoshizakiIce says:
Why didn't we think of that. http://www.hoshizakiice.com/Home_Page.html
Sep 25, 2011. 6:37 AMTheMacyC says:
Awesome!
May 1, 2011. 11:27 AMbuilderkidj says:
Awesome!
Mar 13, 2011. 3:49 PMSHIFT! says:
Hey Tetrinate!
Just wanted to say this build is completely amazing and the results I had with my own Tetris Ice cubes were amazing! Thank you also for inspiring me to create my own Video Game ice casts instructable : http://www.instructables.com/id/FREE-Z-or-How-to-make-VG-Ice-Casts-from-Papercraft/
You Rule!
Jun 4, 2007. 10:04 AMvt13013 says:
Did you tap or vibrate the mold to make sure you didn't have any air bubbles? I noticed a few on the pour images.
Sep 14, 2009. 10:53 AMneckrochylde9 says:
Mixing the silicone very slowly will also help with air bubbles, check the cure time of your rubber first though, most have more than enough time to be patient when mixing. Ideally you would make a vacuum chamber and vacuum the rubber before pouring it. but be sure not to fill your container more than 2 thirds or less or you'll end up with silicone all over your vac chamber! gooey mess!
Mar 8, 2011. 1:53 AMVoid Schism says:
it also helps to use an old brush to paint a layer of silicone over the surfaces, especially where there are overhangs, before pouring the rest
Dec 29, 2010. 6:28 PMrobinhood2605 says:
congrats for your creativity
Dec 1, 2010. 8:52 PMcoppeis says:
Where could I get the silicone and the positive? Also does it have to be food grade?
P.S. I live in the NYC aria and would prefer not to buy it only line any suggestions?
Dec 9, 2010. 11:23 AMneffk says:
I was reading about silicon the other day and noticed that there are several kinds. They differ in the curing agent, which can be platnium or peroxide. Platnuim is safe for projects in which the silicone cures against skin. Not the same as food grade, but related.
Dec 9, 2010. 4:37 PMcoppeis says:
thanks!
Jul 20, 2010. 1:23 PMDr. dB says:
Good Instructable, coherently presented and well photgraphed! I may have to try this, as my wife is an avid (or would that be "rabid"?) Tetris player. I have to keep an NES001 alive and operating on each of our main TVs so she can "satisfy the urge" whenever it strikes... (Plus, the "XBoxed" grandkids are hooked on some of those "quaint, antique" games, too!) Definitely should WASH THE MOLD THOROUGHLY a couple of times, before using, to ensure complete removal of any remaining "release compound". None of them would be very tasty, and some of the "commercial" products are rather toxic... For folks going with wood as their "positive" medium, I would suggest starting with a 1" square moulding strip - might cost a little more but reduces cuts considerably. A hunk of angle iron or a pair of straight 2x4s nailed into a "V" would make a handy "alignment jig" for glueing the shapes. Perhaps a shallow cardboard tray lined with that "release"-type aluminum foil for an expendable mold housing? Hot glue should stick well enough but silicone ought to "peel out" fairly well. Plus, if the hot-gluing is done carefully enough, maybe with some cotton swabs for "dressing-in" the excess around edges, the shapes should "pop" out from behind without much hassle, once the facing foil is removed. (You might even get to keep the undercuts, although the expansion of the water as it freezes might not allow that to work....) This would also make interesting candles, and those needn't be limited to 1" cubes since they wouldn't have to fit a glass...!
Dec 30, 2009. 10:43 PMmikoto says:
Oh my goodness, Now I want to play with silicone.
Jul 20, 2010. 12:27 PMDr. dB says:
hmm... I had that same thought a couple of times while Pam Anderson was "Dancing With The Stars"....
Aug 15, 2009. 4:19 AMendawmyke says:
Did you use COOL AID to color the cubes (sorry for the caps the caps lock gets stuck alot)
Aug 24, 2009. 6:17 AMzazukain says:
Did you not read Step 7? and I doubt that there is something wrong with your caps lock because it just happens to be for the words, "cool" and "aid." Anyway, you could have just fixed it.
Oct 2, 2009. 6:19 AMcowscankill says:
Lol. And why would he apologize for it being stuck if he cuold just backspace and retype it... Some people on the internet just don't have comment sense.
Oct 17, 2009. 9:58 AMM4industries says:
Heheh
comment sense
common sense
was that spelling intended?
Oct 17, 2009. 10:14 AMcowscankill says:
I meant Common but Comment actually works xD
Jan 3, 2010. 12:05 PMpyrorower says:
 Just a typo that happens to fit the context :P
Jul 20, 2010. 12:25 PMDr. dB says:
Serendipity rocks!
Jun 16, 2010. 7:43 AMnodnodwinkwink says:
Theres plenty of novelty ice cube trays out there for sale online and in shops, this would sell too!
Jun 15, 2010. 10:18 PMmyvoiceisdubbed says:
Love this. I was going to give it a 4 1/2, but the very idea of tetris ground beef squares... that's an instant 5/5 right there.
May 26, 2010. 5:09 PMMorriscow says:
 now if only they would disappear when i made rows... hmm *chomp* ow fk my tooth
Feb 18, 2010. 10:17 PMrennoc says:
You can make an awesome game from this instructable!!!
Feb 18, 2010. 7:33 AManniehela says:
I like it. Very nice idea and can create more new ideas..
Jan 10, 2010. 6:23 PMRadke22 says:
Sweet instructable! 5/5! If only I was as creative! =]
My first instructable:
http://www.instructables.com/id/How-to-make-an-ice-fishing-rod/
Oct 20, 2009. 11:10 AMjotism says:
<b><font face="Sawasdee"><a href="http://www.makeyourownmolds.com/">http://www.makeyourownmolds.com/</a><br /> <br /> there should be some useful stuff there...<br /> </font></b>
Sep 27, 2009. 11:49 PMjdc187 says:
where does one get molding silicone from?
Oct 14, 2009. 11:50 AMEgViAgN says:
Oct 1, 2009. 5:17 AMadamgillies says:
Food grade silicone or just normal silicone?
Aug 12, 2009. 7:09 AMHero Under The Pine says:
Definitely gonna use THAT at my next party, Thanks!!! w00t Tetris FTW
Oct 14, 2008. 11:30 PMmickyminime says:
i cant find moulding silicone ANYWHERE!!! im so sad. if anyone knows where, please say.
Jun 25, 2009. 1:33 PMdvsdarrel says:
Have you tried the craft stores in your area? Hobby lobby or Michaels
Apr 5, 2009. 3:48 PMHey Jude says:
bentley chemicals or smooth-on often give sample packs out for a small fee. I recon from the pics that this is the actual company too. good luck, if this post isn't too old!
Jan 2, 2009. 9:23 PMcd41 says:
just a comment but you could use polymorph alittle expensive and not real sure if you can afford/find/want-to-work-with it and might be hard to color unless you got the right grade but if there is absolutly no place for ytou to get molding silicone(to be honest i never heard of it) try it let me know
Apr 30, 2009. 8:25 AMsharlston says:
what is polymorph?
Oct 17, 2009. 10:00 AMM4industries says:
A prototyping material. Some was used in MAKE: 16 SpyTech.
Dont rely on me. Just google it.
1-40 of 240next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
331
Author:Tetranitrate
I'm attending NYU-Poly.
