Tetris Ice Cubes
Step 5Pouring the silicone
  • last photo ←
Mix the silicone according to the directions provided. Pay careful attention to whether it asks to measure by weight or volume.
Pour the silicone mix over the wooden blocks, filling the housing to the rim.
Let set according to the directions provided (usually it will be at least 10 hours).
11 comments
Jun 4, 2007. 10:04 AMvt13013 says:
Did you tap or vibrate the mold to make sure you didn't have any air bubbles? I noticed a few on the pour images.
Sep 14, 2009. 10:53 AMneckrochylde9 says:
Mixing the silicone very slowly will also help with air bubbles, check the cure time of your rubber first though, most have more than enough time to be patient when mixing. Ideally you would make a vacuum chamber and vacuum the rubber before pouring it. but be sure not to fill your container more than 2 thirds or less or you'll end up with silicone all over your vac chamber! gooey mess!
Mar 8, 2011. 1:53 AMVoid Schism says:
it also helps to use an old brush to paint a layer of silicone over the surfaces, especially where there are overhangs, before pouring the rest
May 21, 2009. 9:03 AMNox Caulis says:
Mar 29, 2009. 7:56 AMnaruto the ninja13 says:
make sure you use food grade silicone
Mar 19, 2008. 8:22 PMOmegablood says:
Where do you get the silicone to make the negative mold?
Apr 3, 2008. 10:07 PMshooby says:
might be able to just cut an ice cube or two into the right shapes, might be kind of small unit blocks though
Mar 23, 2008. 12:13 PMjester_rob says:
You might be able to get it at a name brand craft store like Michael's or someplace. I've seen this stuff at the toy train shop by my house so just look around for craft, miniature, or model shops. You might be able to use something like a silicone caulking that you can find at home depot.
Apr 15, 2009. 10:33 AMcwebsterlusk says:
caulking is a bit too thick for this. you cant "pour" it right and it creates air bubbles. least thats my experience.
Sep 14, 2009. 10:50 AMneckrochylde9 says:
Caulking is also NOT food grade silicone and you should never use it for anything your going to ingest . On smooth on's site, they have a product called smooth sil 940 that they say is food safe. I work in film with smooth on products often. Just because it is silicone doesn't make it food grade silicone, Smooth on has a great help line and they will gladly walk you through what to buy for a project like this!
Mar 25, 2008. 8:58 AMOmegablood says:
Do you have a name brand for the stuff or the section to find it in? There are several michaels around here.
Apr 23, 2008. 5:30 PMapburner says:
tap plastic
Try this. I use it for molds for plaster
Apr 23, 2008. 9:24 PMOmegablood says:
thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
324
Author:Tetranitrate
I'm attending NYU-Poly.
