Tetrix Arduino Pinball Robot
866
5
Posted
Introduction: Tetrix Arduino Pinball Robot
Pinball machine with Radio Controlled flippers and Arduino controlled LED's triggered by a Grove Ultrasonic sensor aimed at the bumper pins
Step 1: Chassis and Frame Parts
Chassis and Frame parts:
1 R/C controller & receiver
· 1 Golf ball
· 1 On/ off switch
· 6 3 way beam connector
· 2 Standard servos
· 1 Battery pack
· 4 90 degree gusset
· 6 Quick Rivets
· 4 Thumbscrews
· 4 Wing nuts
· 2 90 degree connectors
· 2 T connectors
· 2 Straight beam connectors
· 3 4 Hole beams
· 2 5 Hole beams
· 6 6 Hole beams
· 2 13 Hole beams
· 1 15 Hole beam
Step 2: Chassis Build
Construct frame, legs, feet, and run servo wires through the channels.
Step 3: Table Support Parts
Table support parts:
· 4 Quick Rivets
· 12 Wing nuts
· 1 Max kep screws
· 9 Max motor screws
· 5 Anchor blocks
· 1 5 Hole linkages
· 2 15 Hole linkages
· 4 7 Hole beams
· 2 6 Hole beams
· 1 4 Hole beam
· 2 15 Hole beams
· 2 T Connectors
Step 4: Construct Table Supports
Install support beams, anchor blocks, and linkages.
Step 5: Table Parts
Table parts:
· 6 6X6 Hole plates
· 2 2x6 Hole plates
· 4 Thumbscrews
· 6 Wing nuts
· 6 Max kep screws
· 2 8 Hole linkages ( bent at hole 2)
Step 6: Game Table
Install plates, and use bumper pins to capture plates.
· 2 80mmAxles
· 6 Thumbscrews
· 2 Set Screws
· 2 Beam end connectors
Step 7: Flipper Parts
Flipper parts:
· 1 5 Hole beam
· 6 Bushings
· 2 Anchor blocks
· 2 Shaft collars
· 2 Max motor shaft hubs
· 4 80mm Axles
· 2 Thumbscrews
· 2 Max motor mount bolts
· 2 80 tooth gears
· 2 40 tooth gears
Step 8: Flipper Gearing
Install flipper arms, anchor blocks, 80mm axles, and servos. Make sure to center the servos before installation.
Step 9: Scoreboard
Pre-assemble the Scoreboard parts and gather the LED'S, cables, and mount clips.
· 1 Ultra sonic sensor
· 1 Max L bracket ( bent)
· 2 LED multi-color light
· 1 Battery
· 8 Quick Rivets
· 6 Max socket head cap screw
· 7 Kep nuts
· 1 2x6 Hole plate
· 2 120 Degree gusset
· 1 13 Hole beam
· 2 8 Hole beam4 4x5 Hole plate
· 6 Thumbscrew
· 5 Wing nuts
Step 10: Install Scoreboard
Install Scoreboard, Ultrasonic sensor, LED'S, and 3D printed game plate.
Step 11: Arduino Parts
Arduino parts:
· 1 Battery
· 1 Arduino kit
· 1 13 Hole beam
· 10 Thumbscrews
· 5 Straight block connectors
· 2 Wing nuts
Step 12: Install Arduino
Fasten mount clips, install and connect Arduino.
Step 13: Finished Pinball Machine
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    Very cool! Thanks for sharing!
