I no longer wish to provide this site with my content for free.
bigJakeK says: Sep 7, 2012. 8:53 AM
Your first comment about not building a smoker with your new welder was the best comment ever, coming from a fellow Texan that is! Looks like you did an amazing job, well done! And God Bless Texas!
2leftthumbs2010 says: Aug 24, 2012. 10:46 PM
pretty sweet work there....I can smell the hickory smoke now!
the tank i have was a water tank in a pumphouse, it's very thick metal, I suppose it may be rusty inside, as it has been sitting for 30+ years,(the tanks is sound, just probably rusty)... I am hoping that I can burn that out, after scraping, scrubing, and sanding until smooth inside so I can season w/ oil, think that will do it? The tank i have access to is about 5 1/2 ft high, approx. 26 inches diameter....similar i suppose.
Did you make a system that allows you to raise and /or lower the grill grates for different heights? Do you think it would be useful or come in handy, maybe even have it split into two or three sections that could be moved to different heights if it was convenient or helped the smoking of different sized items, any comments?
I notice in some pics, the thermometer is on the endof tank near the firebox and i others it appears to be on door? Suggestions? Is it easy to source the type of thermometer used?
Airflow from firebox to grill, I am thinking you can control it, with a vented circular disc...do you, after building and using this, do you have further suggestions on the placement of firebox relative to end of grill,(how far offset from center seems best?)
Any other suggestions after your completion of this great project for design considerations, things to be aware of, careful of. etc....
You did a great job by the loks of it, just curious if you have additional pointers.
Thanks for the super posting!
TexasBaconMan (author) in reply to 2leftthumbs2010Aug 25, 2012. 10:47 AM
The supports for the grill grate are fixed. Due to the fact that the cross section is a circle you can't have multiple locations for the same grate. I have seen some designs that had supports for multiple grates. If I had not done the hanging rod, I may have done that.
That is not a thermometer on the end of the tank. It's a knob that can be unscrewed to remove the hanging rod. The one on the door was easy to install, available at Academy.
The airflow worked well. I did have to leave the door open at times. Most important was the baffle inside that blocks the heat from the stuff on the end. It worked very well. Here is the source for the damper: http://www.kck.com/bbq_air_damper_smoker_pit_grill.html
If I were to do it again: I would have not put the support under the firebox, it only ever got in the way. It was not needed. I would have put wheels on it, somehow. Possibly on a trailer. I also would have made the door on the firebox go all the way to the bottom, for easier clean out.
additional tips: it take some to get it up to temp but when it is, it can stay there for hours.
good luck ,post when you have pics, even if it's not done.
2leftthumbs2010 in reply to TexasBaconManAug 25, 2012. 2:01 PM
Thank you for prompt reply, Mr. TexasBaconMan, it will be a couple months before I am back on my farm where the tank is, I was just researching BBQ's/smokers last night as I couldn't sleep. I am going to build one at a house here in NC, out of block/firebrick, and brick...there are two on this site that appeal to me, one is a DIY all in one grill.oven smoker from Mother Earth Newsmag, the other is posted and comes up w/the related items search, I can't remeber the posters name, but it has basically one side that is a brick grill, and that connects to the oven/smioker....I think some of the principles for airflow will be the same for your design and the brick one .....and as far as heating the things up for a while before cooking, that is gonna happen, I have to do that w/ my commercial charmaster barrel smoker/w side firebox....takes an hour to build up a great bed of hickory coals to keeep the barrel at 225-250 which I have found is plenty hot enough, maybe even too hot for that size barrel....ribs are done in 3 -3 1/2hours...
I will take into account your suggestions, and when I get going on either of the two projects I will shoot you some pics, thanks again for taking the time to reply...
corvair66 says: Oct 19, 2011. 7:33 PM
That's awesome! I am looking to make something like this. I already have an old grill made from a water heater that a friend gave me (see photo). It lacks the firebox, though I have smoked many racks of ribs in it by simply putting the coals on the ends of the grill and the meat in the middle. I love using a water heater as a base because it's thick and meant to hold in heat. I'm interested in making something smaller than the one I have now and construct it so it comes apart from the base so I can transport it. I bought the Brinkman smok'n pit on the left of the photo, but it's so flimsy, I can't get it up to 100 degrees in the sun with a welding blanket on it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
