Text to Speech Batch Program
33,699
16
37
Posted
Introduction: Text to Speech Batch Program
As I promised earlier, I have made this instructable. This is part of a set of instructables I am making that focuses around one of the original features in my Mega_Menu V 2.4 batch program. I have one other, previously made instructable on my address book program which you can find here
This program has one major function only, making your computer "speak" whatever you write in the program. This is accomplished by creating a separate (temporary) VBs file that makes SAPI speak whatever you write. This file is deleted afterwards.
Onto the code:
Note: I made a mistake, don't use underscores, use hyphens. I have corrected this.
Step 1:
@echo off
title Text to Speech Conversion
color 0a
rem The user decides what to convert here
:input
cls
echo What do you want the computer to convert into speech?
echo.
set /p text=
rem Making the temp file
:num
set num=%random%
if exist temp%num%.vbs goto num
echo ' > "temp%num%.vbs"
echo set speech = Wscript.CreateObject("SAPI.spVoice") >> "temp%num%.vbs"
echo speech.speak "%text%" >> "temp%num%.vbs"
start temp%num%.vbs
pause
del temp%num%.vbs
goto input
If you do not want the screen to close for no reason, I suggest you follow the tip given and don't use spaces; use hyphens (-) instead.
Step 2:
That's it. I don't know why I added this last step, but all the cool-kids are doing it nowadays. Have fun?
P.S It said I needed more photos, so I gave Instructables a cheetah.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    34 Comments
    Awesome PP, just changed your code so that it takes multiple lines of input. Best thing is since the "SAPI.spVoice" pauses just after it finishes, at the end of each line there is a slight pause.
    @echo off
    color 0a
    :start
    cls
    echo.
    :num
    set num=%random%
    rem Taking Input
    :input
    set text=
    set /p text=
    if not "%text%"=="" (
    goto :input
    start temp%num%.vbs
    Pause Echo Speaking . . .
    del temp%num%.vbs
    goto start
    Just wondering do you know of any other auto-voicing programs installed by default in a windows computor?
    Found error: 3rd Last line -
    Pause |Echo Speaking . . .
    Thanks for your help, and no. There are no pre-installed auto-voicing programs on Windows that I know of, but I'm sure there's some free or open-source programs for download.
    Remove "|Echo Speaking . . ."
    I think that will work
    I am currently working on a tiny bot and want to add ur TTS code..i did that and its not working ..can u tell me what i did wrong?..im new to this..!
    this is my code:
    @echo off
    mode 1000
    if not exist data.txt echo.>data.txt
    echo HI!..I am BabyBot.I am a tiny AI bot.Please teach me how to interact with humans!
    echo.
    Echo.
    echo Press any key if you are interested in helping me!
    pause > nul
    :getName
    ECHO.
    Echo.
    echo WHAT IS YOUR NAME?
    set "name="
    SET /P NAME=
    if not defined NAME goto getName
    ECHO HI, %NAME% !
    set /p text= HI
    :num
    set num=%random%
    start temp%num%.vbs
    pause >nul
    del temp%num%.vbs
    pause
    :begin
    set /p text="Ask me something %name% : "
    for /f "tokens=1,* delims=@" %%i in (data.txt) do (
    if /i "%text%"=="%%i" (
    echo *** %%j
    goto begin
    echo --- I don't know that.
    set /p answer=--- What would be a good answer to '%text%'?
    echo %text%@%answer%>>data.txt
    echo --- thank you
    goto begin
    thank you for all the tutorials btw
    i need help
    which coding language is used here. please tell me how to use this code so that it may convert text to speech
    Can we change the language.. I need Korean!!
    Do something like:
    speech.speak "Some--Text--Here"
    speech.speak "Are--We--Clear"
    And save as .vbs
    Intead of adding the lines into .bat
    call the .vbs from .bat
    Note:Additional Information
    Voice1 starts in sequence line while Voice2 and Text2 starts at the same time by adding the start command.
    @echo off
    Voice1
    start Voice2
    start Text1
    I hope it Helps
