Texting Mat
6,962
36
Posted
Introduction: Texting Mat
Lusha and May created a "Text-Mat”. This surface can allow the user to write and send messages using one’s feet. This text-mat is designed to send secret messages during meetings or classes. The design utilizes conductive fabric and thread, as well as a flora-board. The program contains 7 preset sentences. The user can press a button to select the appropriate sentence and then a final button to send.
Please enjoy the video:
https://vimeo.com/81472818
Step 1: Text-Mat
Step 2:
 Next, we cut the wool, felt and conductive fabrics to the desired sizes.
Step 3:
3. We then used the sewing machine to sew the fabrics together.
Step 4:
. 4. Next, we sewed the conductive thread to make a circuit with the conductive fabric.
Step 5:
5. Then we ironed the edges flat.
Step 6:
6. Then we connected the flora board into the circuit.
Step 7:
7. We prepared the following code for the flora: _________
Step 8:
8. We then connected the smart phone and Arduino with the USB connection.
Step 9: Code
The code:
#include
CapPin cPin_10 = CapPin(10);    // read pin 10 (D10 on Flora) - connect to NES B
CapPin cPin_9  = CapPin(9);     // read pin 9 (D9 on Flora)   - connect to NES A
CapPin cPin_6  = CapPin(6);     // read pin 6 (D6 on Flora)   - connect to NES Start
CapPin cPin_12 = CapPin(12);    // read pin 12 (D12 on Flora) - connect to NES Select
CapPin cPin_1  = CapPin(1);     // read pin 1 (TX on Flora)   - connect to NES right
CapPin cPin_0  = CapPin(0);     // read pin 0 (RX on Flora)   - connect to NES up
CapPin cPin_2  = CapPin(2);     // read pin 2 (SDA on Flora)  - connect to NES left
CapPin cPin_3  = CapPin(3);     // read pin 3 (SCL on Flora)  - connect to NES down
CapPin pins[] = {cPin_10, cPin_9, cPin_6, cPin_12, cPin_1, cPin_0, cPin_2, cPin_3};
// check http://arduino.cc/en/Reference/KeyboardModifiers for more info on unique keys
// WASD D-pad, select = Return, start = Space, LeftButton = z, RightButton = x
//char Keys[] =   {  'x',    'z',    ' ',     KEY_RETURN,    'd',     'w',    'a',    's'};
// arrow D-pad, select = Return, start = Space, LeftButton = b, RightButton = a
//char Keys[] =   {  'a',    'b',    ' ',     KEY_RETURN, KEY_RIGHT_ARROW, KEY_UP_ARROW, KEY_LEFT_ARROW, KEY_DOWN_ARROW};
char* Keys[] =   {"hello", "winkyface", "you there?", "hi", "I'm bored", "let's meet for lunch", "zzz", "bye"};
boolean currentPressed[] = {false, false, false, false, false, false, false, false};
// Capactive touch threashhold, you might want to mess with this if you find its too
// sensitive or not sensitive enough
#define THRESH 500
float smoothed[8] = {0,0,0,0,0,0,0,0};
void setup()
  //while (!Serial)
  Serial.begin(115200);
  Serial.println("start");
  Keyboard.begin();
void loop()
  for (int i=0;i<8;i++) {
    delay(1);
    long total1 = 0;
    long start = millis();
    long total =  pins[i].readPin(2000);
    // check if we are sensing that a finger is touching the pad
    // and that it wasnt already pressed
    if ((total > THRESH) && (! currentPressed[i])) {
      Serial.print("Key pressed #"); Serial.print(i);
      Serial.print(" ("); Serial.print(Keys[i]); Serial.println(")");
      currentPressed[i] = true;
      Keyboard.println(Keys[i]); //sends string as keyboard presses, ending with the ENTER key
    else if ((total <= THRESH) && (currentPressed[i])) {
      // key was released (no touch, and it was pressed before)
      Serial.print("Key released #"); Serial.print(i);
      currentPressed[i] = false;
      Keyboard.releaseAll();
    // simple lowpass filter to take out some of the jitter
    // change parameter (0 is min, .99 is max) or eliminate to suit
    smoothed[i] = smooth(total, .8, smoothed[i]);
    Serial.print(i); Serial.print(": ");
    Serial.print( millis() - start);      // time to execute in mS
    Serial.print("ms \t");
    Serial.print(total);                  // raw total
    Serial.print("\t->\t");
    Serial.println((int) smoothed[i]);       // smoothed
    delay(5);
// requires recycling the output in the "smoothedVal" param
int smooth(int data, float filterVal, float smoothedVal){
  if (filterVal > 1){      // check to make sure param's are within range
    filterVal = .999999;
  else if (filterVal <= 0){
    filterVal = 0;
  smoothedVal = (data * (1 - filterVal)) + (smoothedVal  *  filterVal);
  return (int)smoothedVal;
Step 10:
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
3 Comments
Interesting idea. Using the Arduino as an interface makes it very flexible. Thanks for posting.
Your code is missing, otherwise a rather interesting idea.
