Texturing Metal - IDC Workshop
404
10
Posted in WorkshopMetalworking
Introduction: Texturing Metal - IDC Workshop
with this instructable we want to show you a few tips and tricks on how to paint and texturize metal surfaces.
the right color and finish is very important in a product, you can camouflage flaws with matte paints whereas you can see the tiniest imperfection with a glossy paint.
BUT DONT WORRY...in this instructable we'll show you all the things you need to know.
Step 1: Paint Choice
the choice of your paint depends on a lot of factors, these are:
what material are you gonna paint?
for use indoors or outdoors?
the material's surface
tempratures
time to dry
need for a primer
Step 2: Work Area
Don't have acces to a paint booth?
no worries! just use a cardboard box to spray your part in.
this way you keep your walls save from an unwanted colorchange
Step 3: Degreasing
this step is very important.
clean the surface you wanna paint thoroughly with some paint thinner.
paint won't adhere on a dirty surface and on top of that, you'll get a poor finish.
Step 4: Prepping Your Spraycan
remove the little plastic thingy under the nozzle, after that put the nozzle back on. Make sure you dont spray paint all over your face though.
now shake intensly for a good minute or two
you're almost ready to start painting now
Step 5: Spraying Distance
normally a good distance between your nozzle and your part is about 30cm
its also recommended to spray very lightly at first. spraying your paint on to thick will cause "runners". you want to avoid these at all times.
Step 6: Actually Painting.... (finally)
in a fluid Z motion paint the piece from the bottom to the top. Start spraying about 5cm in front of the piece and end about 5cm behind it.
on some parts you'll need to use a primer for the best finish. The safest choice for a primer is white.
ATTENTION
spray to slow and the paint will be to thick
spray to fast and the paint wont cover enough (this is always the best choice of the two because you can always add some paint)
Step 7: Varnishing
varnishing is more difficult because you can't see where you're spraying
just keep spraying the way you've learned before and youl be ok.
Step 8: Cleaning Up
Once everything is painted, it’s important
that you get the last bit of paint out of the nozzle of the can, this prevents the paint from hardening inside the tube. This is easily done by holding the can upside down and spray until only air comes out. The nozzle can also be cleaned by letting it sit inside a cup with paint thinner , this loosens the paint that is stuck inside the nozzle.
Step 9: Dry Time
Always respect the curing time, this is
clearly indicated on the paint can. By respecting that time you can be sure the piece won’t have fingerprints on it when you pick it up or you can spray on the next coat.
Step 10: Texturing
Sanding
Sandblasting
Polishing
By giving your product texture, you can create special effects, for example making the piece look older than it actually is or you could make it shine so bright that you’ll be blinded.
Step 11: Sanding
Sanding can be done in a variety of
different ways, everything depends on the material you use. When sanding aluminium it’s best to you use sanding paper with a 300 grain. While in the case of metal you best use a sanding machine.
Step 12: Sandblasting
By sandblasting your metal you can create
rougher textures, the advantage of this is that you can eliminate scratches/imperfections on the metal. WATCH OUT if you want a figure sandblasted into an aluminium piece, it’s best to sandblast first and paint later then tape the figure on the piece and sandblast again. This is to ensure that your paint doesn’t stick to the tape when you pull it off. The paint sticks better to a rougher (sandblasted) surface.
Step 13: Polishing
polish your metal piece by rubbing a very fine abrisive compound on your metal with a cloth. The amount of shine depends on how long you rub the piece.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
