If your looking for something sweet to take to Thanksgiving that isn't a pie...I've got something fun for you! Why not bring Thanksgiving dinner for d...
To make these cupcakes the main items your going to need are: 12 cupcakes + one extra for decoration ( I recommend pumpkin ones for color) / recipe he...
You will need to separate your buttercream into 4 bowls. Using gel coloring dye one a light yellow, one a yam color (copper + a little brown) , one a ...
Now color your fondant using gel coloring, a few oz of each color will be plenty for a dozen cupcakes. You will need a light yellow, a dark green, and...
For the mash potatoes start by using an ice cream scoop to put on a nice large scoop of white buttercream. Then smooth it out a bit with a small spatu...
For the green bean casserole use a large round tip to pipe on a flat swirl of icing on the cupcake then smooth it out with a Viva towel. Roll the dark...
To make the corn cob roll out yellow fondant and roll it out into long coils about 1/4 inch wide and about 4 in long. Then use a knife and press lines...
Using your tan buttercream pipe a slightly off center tall swirl on the cupcake, then use a Viva towel to gently smooth out the lines. You will simply...
Take the extra cupcake and cut into little square chunks to make the stuffing. Pipe a flat swirl of buttercream onto the cupcake using your tan from t...
For the yams use a large round icing tip and pipe on blobs of icing. Then smooth out the tips with a Viva paper towel. Then sprinkle a bit of brown su...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
