Thats Hot
Published
Introduction: Thats Hot
The Simple Thermostat
Step 1: Project Overview and How To:
This program and build will make a simple thermostat. The screen displays the room temp in Fahrenheit and Celsius, changed by the press of the button, and the Desired Temp. The desired Temperature is set by an Potentiometer will turn on a heater/air conditioning (Represented by the LED) when its set to a certain temp. To build this broject, follow the circuit picture and the use the code.
Troubleshooting:
If this doesnt work after assembled, check to make sure all of the program is present and the wiring is correct
Step 2: Program:
#include <LiquidCrystal.h>
const int buttonPin = 13;
const int temperaturePin = 0;
int sensorPin = 1; float
desiredTemp = analogRead(sensorPin);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
lcd.begin(16, 2);
Serial.begin(9600);
pinMode(buttonPin, INPUT);
lcd.print("");
pinMode(8,OUTPUT);
void loop() {
int buttonState;
float desiredTemp = map(analogRead(sensorPin),0,1023,50,85);
Serial.println(desiredTemp);
float voltage, degreesC, degreesF;
voltage = getVoltage(temperaturePin);
degreesC = (voltage - 0.5) * 100.0;
degreesF = degreesC * (9.0/5.0) + 32.0;
Serial.print("voltage: ");
Serial.print(voltage);
Serial.print(" deg C: ");
Serial.print(degreesC);
Serial.print(" deg F: ");
Serial.println(degreesF);
delay(1000);
buttonState = digitalRead(buttonPin);
lcd.clear();
lcd.setCursor(11,0);
lcd.print("Des.");
if(buttonState== LOW){
lcd.setCursor(0, 1);
lcd.print(degreesC);
lcd.setCursor(0, 0);
lcd.print("Celsius");
lcd.setCursor(11,1);
lcd.print(desiredTemp); }
else {
lcd.print(degreesF);
lcd.print("Fahrenheit");
if(desiredTemp >= 75){
digitalWrite(8,HIGH); }
else if(desiredTemp <= 74) {
digitalWrite(8,LOW); }
float getVoltage(int pin) { return (analogRead(pin) * 0.004882814); }
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    Thanks for sharing :)
